  3. Writing a waveform and sampled version of that into a file...
  • Replies 9
  • Subscribers 131
  • Views 25957
Writing a waveform and sampled version of that into a file without using ocnPrint
yayla
yayla over 14 years ago
Hi all,
       I have recently started to learn ocean script and tried to make some analysis. I have looked at the forum to find a solution but I couldn't. My problem is that I am running a tran analysis and saving voltages by writing save('v "/outp"). After that, I am sampling this wave with some step as
out_sampled = sample(VT("outp") 1e-8 4e-8 "linear" 1e-12)
My question is that without using ocnPrint how I could save wave itself (VT("/outp") and out_sampled) into a file. Probably, I will need to use fprintf() but I am not quite sure how to do that.
I will appreciate if you could help.
 yayla
    port=outfile("report.txt")
    ocnPrint(?output port VT("outp"))
    ocnPrint(?output port out_sampled)
    close(port)
    You don't want to pass both signals (raw and sampled) at the same time to ocnPrint, because otherwise it will print a table with a common x-axis, and the sampled signal will end up being interpolated. In other words, don't use ocnPrint(VT("outp") out_sampled)
  • yayla
    Thanks Andrew for your reply. Good to learn the interpolation issue.
     I am wondering whether there is any other way to print those into a file instead of using ocnPrint like using fprintf() or other functions
     Also should I create a port with append mode and is it not necessary if I an writing two ocnPring concurently?, i.e.
    port=outfile("report.txt")  ===> port=outfile("report.txt" "a")
    close(port)
    yayla
    There's no need to open in append mode unless you want to append to the previous contents of the file (i.e. not overwrite it at the time of opening). Each succesive ocnPrint with the same port will append to the output stream until the file is closed.
    You can't use fprintf with a waveform object; you'd have to iterate over the points in the waveform object - for example:
    /* abDumpWaveform.il
    Author     A.D.Beckett
    Group      Custom IC, Cadence Design Systems Ltd.
    Machine    SUN
    Date       Oct 23, 1997
    Modified   Jan 31, 2005
    By         A.D.Beckett
    Functions for dumping a waveform to a file
    Examples:
    abDumpWaveform(VT("/c") "data_c.out")
    abDumpWaveform(VT("/c") "data_c.out" "%e %e\n") ;; exponential format
    abDumpWaveformSplit() is equivalent to abDumpWaveform, but splits
    into files a little less than 2Gbytes (the split limit is an optional
    argument).
    ;; sampled output.
    ;; note that linRg and logRg generate a range of values,
    ;; with args from, to, step.
    abDumpSampledWaveform(VT("/c") linRg(0.01 0.05 0.005) "data_c.out")
    ;; multi-variable output
    ;; all waveforms must share same x-axis, as it doesn't do any interpolation (for
    ;; speed reasons). Interpolation could be done by collecting all the x-values, and
    ;; then using the value function.
    abDumpWaveforms("data.out" VT("/c") VT("/z") VT("/a"))
    abDumpWaveforms("data.out" VT("/c") VT("/z") VT("/a") ?format "%-10g" ?separator ",")
    ;; can also write out multiple files if presented with a family
    abDumpFamily(VT("/c") "data.out")
    SCCS Info: @(#) abDumpWaveform.il 11/20/08.15:26:13 1.6
    *  (abDumpWaveform wave fileName @optional (format "%g %g\n"))   *
    * Take a waveform object, write it out to the fileName specified *
    *          with the format given. No sampling is done.           *
    (procedure (abDumpWaveform wave fileName @optional (format "%g %g\n"))
      (let (port (xVec (drGetWaveformXVec wave))
                 (yVec (drGetWaveformYVec wave)))
           (unless (setq port (outfile fileName))
                   (error "Could not write to file %s\n" fileName))
           (for pos 0 (sub1 (drVectorLength xVec))
                (fprintf port format
                         (drGetElem xVec pos)
                         (drGetElem yVec pos))
           (close port)
    *         (abDumpWaveformSplit wave fileName @optional           *
    *            (format "%g %g\n") (split 2**31-512) )              *
    *     with the format given. No sampling is done. Splits into    *
    *      multiple files when the number of bytes exceeds split     *
    (procedure (abDumpWaveformSplit wave fileName @optional (format "%g %g\n") (split 2**31-512))
                 str (len 0) (suffix 0))
                (sprintf str format
                (setq len (plus (strlen str) len))
                (when (greaterp len split)
                      (close port)
                      (postincrement suffix)
                      (setq len (strlen str))
                      (unless (setq port (outfile (sprintf nil "%s_%d" fileName suffix)))
                              (error "Could not write to file %s_%d\n" fileName suffix))
                (fprintf port "%s" str)
           (close port)
    * (abDumpFamily family fileNamePrefix @optional (format "%g %g\n")) *
    * Write out a sequence of files for a family. Could potentially do  *
    *  this automatically inside abDumpWaveform, but it's hard without  *
    *                     using private functions.                      *
    (procedure (abDumpFamily family fileNamePrefix @optional (format "%g %g\n"))
      (let ((xVec (drGetWaveformXVec family))
            (yVec (drGetWaveformYVec family))
            index
           (if (drIsWaveform family)
               ; then
               (abDumpWaveform family fileNamePrefix format)
               ;else
                    (setq index (drGetElem xVec pos))
                    (unless (stringp index)
                            (sprintf index "%L" index))
                    (rexCompile "[^a-zA-Z0-9.]")
                    (setq index (rexReplace index "_" 0))
                    (abDumpWaveform
                     (sprintf nil "%s_%s" fileNamePrefix index)
                     format
               ) ; if
    *   (abDumpWaveforms fileName @key (format "%g") (separator " ") @rest waves)    *
    *    Write out a group of waveforms with a common x-axis to a file. It checks    *
    * to see if the x-axis is the same, because otherwise some kind of interpolation *
    *    would be necessary. An optional format string can be specified, so that     *
    *   the precision can be controlled. Also, an optional separator may be given.   *
    (procedure (abDumpWaveforms fileName @key (format "%g") (separator " ") @rest waves)
      (let (port xVec)
           (setq xVec (drGetWaveformXVec (car waves)))
           ; check to see if all waveforms have same X-axis
           (when (exists wave waves (neq xVec (drGetWaveformXVec wave)))
                 (error "All waveforms must have same x-axis")
                (foreach wave waves
                         (fprintf port "%s" separator)
                         (fprintf port format (drGetElem (drGetWaveformYVec wave) pos))
                (fprintf port "\n")
           (close port)
    * (abDumpSampledWaveform wave samplePoints fileName @optional (format "%g %g\n")) *
    *      Dump the waveform at the sampled points passed in. wave is a waveform      *
    *            object, samplePoints is a list of x points to sample at,             *
    * fileName is the file to write to, and format is an optional formatting string.  *
    (procedure (abDumpSampledWaveform wave samplePoints fileName @optional (format "%g %g\n"))
      (let (port)
           (foreach point samplePoints
                             point
                             (value wave point))
           (close port)
  • yayla
    Thanks Andrew.  They are perfect and they will be very useful for me and others. However, using fprintf doesn't seem so much easy. Probably, I will use ocnPrint but the issue about ocnPrint is that there are some redundant lines and I don't know how to get rid of those.
    yayla
    Of course, you can always use the abDumpWaveform code as I supplied it and modify it to suit your needs (if it doesn't already do what you want).
  • yayla
    Andrew, a quick question: is it possible to save "out_sampled" under psf folder like net voltages or currents( save('v ("/outp")) ) so that I could reach out_sampled using Spectre/RF MATLAB Toolbox(cds_srr command) ?
     yayla
    Yayla,
    Not really. You could sample the signal in Matlab, I guess - one way is to use cds_interpsig(sig,'time',20) to sample it to 20 evenly spaced points.
    There's also some functions I wrote a while back to dump out PSF - but I have not tested these in ages (I removed them from the abDumpWaveforms.il listing above in order to make it a little shorter):
    * Some global variables which enable simpler specification of the header *
    *                      part of the ASCII PSF file.                       *
    (setq abAsciiPSFTokenMap
      '((TOK_CR "\n")
        (TOK_PROP "PROP( ")
        (TOK_STRUCT "STRUCT( ")
        (TOK_OPEN "( ")
        (TOK_CLOSE ") ")
        (TOK_STAR "* ")
    (setq abAsciiPSFHeader
        HEADER TOK_CR
        "PSFversion" "1.00" TOK_CR
        TYPE TOK_CR
        "sweep" FLOAT DOUBLE TOK_PROP TOK_CR
        "key" "sweep" TOK_CR
        TOK_CLOSE TOK_CR
        "V" FLOAT DOUBLE TOK_PROP TOK_CR
        "units" "V" TOK_CR
        "key" "node" TOK_CR
        "tolerance" 1.00000e-06 TOK_CR
        TOK_CLOSE TOK_CR
        SWEEP TOK_CR
        "time" "sweep" TOK_PROP TOK_CR
        "sweep_direction" 0 TOK_CR
        "units" "s" TOK_CR
        "plot" 0 TOK_CR
        "grid" 1 TOK_CR
        TOK_CLOSE TOK_CR
    (setq abAsciiPSFLogFile
        HEADER TOK_CR
        "Log Generator" "drlLog rev. 1.0" TOK_CR
        "Log Time Stamp" "Thu Jan  3 16:23:59 2002" TOK_CR
        "simulator" "spectre" TOK_CR
        "version" "4.4.6.122001" TOK_CR
        "date" "4:23:59 PM, Thur Jan 3, 2002" TOK_CR
        "design" "myres.scs" TOK_CR
        TYPE TOK_CR
        "analysisInst" TOK_STRUCT TOK_CR
        "analysisType" STRING TOK_STAR TOK_CR
        "dataFile" STRING TOK_STAR TOK_CR
        "format" STRING TOK_STAR TOK_CR
        "parent" STRING TOK_STAR TOK_CR
        "sweepVariable" ARRAY TOK_OPEN TOK_STAR TOK_CLOSE STRING TOK_STAR TOK_CR
        "description" STRING TOK_STAR TOK_CR
        TOK_CLOSE TOK_CR
        VALUE TOK_CR
        "tran-tran" "analysisInst" TOK_OPEN TOK_CR
        "tran" TOK_CR
        "tran.tran" TOK_CR
        "PSF" TOK_CR
        "" TOK_CR
        TOK_OPEN "time" TOK_CLOSE TOK_CR
        "Transient Analysis `tran'" TOK_CR
        TOK_CLOSE TOK_CR
        END TOK_CR
    *                 (abDumpPSFMagic port magic)                  *
    *   A function for dumping the "magic" tokenised PSF header    *
    *  format information, to make writing the ASCII PSF simpler   *
    *                    (believe it or not...)                    *
    (procedure (abDumpPSFMagic port magic)
      (let (mapped)
           ; Ensure that the PSF token map has been created
           (unless (boundp 'abPSFTokenMap)
                   (setq abPSFTokenMap (makeTable 'PSFTokenMap nil))
                   (foreach tokenMap abAsciiPSFTokenMap
                            (setarray abPSFTokenMap (car tokenMap) (cadr tokenMap))
           ; Now write out each word in the magic list, mapping if necessary
           (foreach word magic
                    (if (setq mapped (arrayref abPSFTokenMap word))
                        (fprintf port mapped)
                        (progn
                         (print word port)
                         (fprintf port " ")
    *       (abDumpWaveformsToAsciiPSF fileName @rest waves)       *
    *     Create an ASCII PSF file containing the waves passed     *
    *  as remaining arguments. Note that all must have the same X  *
    *                             axis                             *
    (procedure (abDumpWaveformsToAsciiPSF fileName @rest waves)
      (let (port xVec (waveNum 1))
           ; If a list of waves is passed in, use that instead
           (when (listp (car waves)) (setq waves (car waves)))
           ; Get the x vector of the first waveform
           ; much simpler this way...
           (abDumpPSFMagic port abAsciiPSFHeader)
           (abDumpPSFMagic port `(TRACE TOK_CR "group" GROUP ,(length waves) TOK_CR))
           ; Create a waveform name for each waveform
                           (foreach mapcan wave waves
                                    ; next line is just to fool lint
                                    wave
                                    (list (sprintf nil "wave%d" (postincrement waveNum)) "V" 'TOK_CR)
           (abDumpPSFMagic port `(VALUE TOK_CR))
           ; Now write out the actual data
                (fprintf port "\"time\" %.14e\n\"group\" " (drGetElem xVec pos))
                (foreach wave waves
                         (fprintf port "%.14e\n" (drGetElem (drGetWaveformYVec wave) pos))
           (abDumpPSFMagic port `(END TOK_CR))
           (close port)
    *         (abDumpWaveformsToBinPSF rawdir @rest waves)         *
    *   Specify a raw directory, and a number of waveforms, this   *
    *      will create an ASCII PSF file and then use the psf      *
    *               utility to convert it to binary.               *
    (procedure (abDumpWaveformsToBinPSF rawdir @rest waves)
      (let (port)
           (if (or (isDir rawdir) (createDir rawdir))
               (progn
                (apply 'abDumpWaveformsToAsciiPSF (cons (strcat rawdir "/tran.asc") waves))
                (setq port (outfile (strcat rawdir "/logFile")))
                (when port
                      (abDumpPSFMagic port abAsciiPSFLogFile)
                      (close port))
                ; Use the transpose option (-x) (think this is right...)
                (system
                 (sprintf nil "psf -x -i %s/tran.asc -o %s/tran.tran"
                          rawdir rawdir)
                t
               (error "Could not create directory %s" rawdir)
    In fact rather than using cds_interpsig it's probably even easier to use the Matlab function interp1.
    net51=cds_srr('Results/psf','tran-tran','net51')
    newX=1e-9:0.2e-9:8e-9
    net51samp=interp1(net51.time,net51.V,newX)
    plot(net51.time, net51.V,newX,net51samp)
    If I plot this:
    stem(newX,net51samp)
    I get the attached picture/
  • yayla
     Thanks for the valuable information you gave. Matlab interp1 function seems a good a solution. I will try that as soon as posssible.
    Have a nice weekend.
    yayla.
