  3. QRC stand alone mode.
  • Subscribers 133
  • Views 15071
MadapusiSriniv
MadapusiSriniv over 10 years ago
Hello all,
I am trying to do SSTA analysis, for which I need to create a SSPEF File. I am tryin to run the stand alone extraction, but I get a strange error attached in the end. Not sure what this means, but I suspect I am not able to access QRC stand alone, can someone please tell me which exact QRCX* package I need for extracting in signoff ? I have this issue running on EXT , and even invoking it from EDI.
INFO (EXTGRMP-260) : Layer cluster settings were not specified.
INFO (EXTHPY-168) : Input stage started at Thu Jun 25 21:54:44 2015.
/usr/scratch2/dmsp8/sens/RAND_sim_ssta_trial/sample/encounter/./.dpw.26654.100000.exe: line 9: syntax error near unexpected token `='() { eval `/usr/bin/modulecmd bash $*`
/usr/scratch2/dmsp8/sens/RAND_sim_ssta_trial/sample/encounter/./.dpw.26654.100000.exe: line 9: `}''
/usr/scratch2/dmsp8/sens/RAND_sim_ssta_trial/sample/encounter/./.dpw.26654.100011.exe: line 9: syntax error near unexpected token `='() { eval `/usr/bin/modulecmd bash $*`
/usr/scratch2/dmsp8/sens/RAND_sim_ssta_trial/sample/encounter/./.dpw.26654.100011.exe: line 9: `}''
thank you
Divya
  • Quek
    Quek over 10 years ago
    Hi Divya
    It looks like you are accessing the tool from a wrapper. This could be the cause of the problem. Would you please provide the output of the following cmd?
    terminal>which qrc
    Quek
  • BCSS
    BCSS over 10 years ago
    I have the same error...
    for me the path to qrc is:
    $ which qrc
    /local/tools/EXT_14.11.000/bin/qrc
    there are no links to the tool, and no mounts... it is in the same machine and enviroment
    and i get the error when QRC is called by encounter
    INFO (EXTHPY-168) : Input stage started at Sun Dec 13 10:38:22 2015.
    /local/users/bruno/cadence_wd/615/tsmc13soc_wd/mpw2_t604/./.dpw.18351.100000.exe: line 181: syntax error near unexpected token `='() { eval `/usr/bin/modulecmd bash $*`
    /local/users/bruno/cadence_wd/615/tsmc13soc_wd/mpw2_t604/./.dpw.18351.100000.exe: line 181: `}''
    /local/users/bruno/cadence_wd/615/tsmc13soc_wd/mpw2_t604/./.dpw.18351.100011.exe: line 181: syntax error near unexpected token `='() { eval `/usr/bin/modulecmd bash $*`
    /local/users/bruno/cadence_wd/615/tsmc13soc_wd/mpw2_t604/./.dpw.18351.100011.exe: line 181: `}''
    /local/users/bruno/cadence_wd/615/tsmc13soc_wd/mpw2_t604/./.dpw.18351.100022.exe: line 181: syntax error near unexpected token `='() { eval `/usr/bin/modulecmd bash $*`
    do you have any update on this thread?
