  3. automatic highlights
  • Subscribers 131
  • Views 16732
Karev11
Karev11 over 10 years ago
I posted a question about codes to highlight schematic nodes with thicker lines and Larry provided me codes below:
packets = foreach(mapcar lay '("y0" "y1" "y2" "y3" "y4" "y5" "y6" "y7" "y8" "y9")
  pack = drGetPacket("display" strcat(lay "_drawing"))
  setcar(cdddr(pack) "thickLine")
  apply('drSetPacket pack)
  pack)
which works perfectly.
I wonder if anyone could provide the code to set it to default so that there's no need to copy these lines of code to CIW everytime?
thanks,
    It depends on how the colors (colours for me!) are being set. If the PDK is doing a drLoadDrf() from within the libInit.il of the technology library, this gets a bit more complicated (especially if you need to make this work in IC5141). If not, then it's just a matter of updating your display.drf with the Display Resource Editor and then putting that in your working directory (or doing a drLoadDrf("/path/to/display.drf" nil) in your .cdsinit after any other has been loaded.
    If it's being loaded by a PDK's libInit.il file, then you need to add a trigger to load your own (or run this SKILL code) after the PDK's libInit.il has been read. This can be done using the code in this post. Then do:
    procedure(myDoSomethingAfter(libName)
      printf("Override the default display.drf for %L\n" libName)
      drLoadDrf("/path/to/some/display.drf" nil)
      t
    abDoSomethingAfterLibInit("gpdk090" 'myDoSomethingAfter)
    Or rather than the drLoadDrf, you could put the code above in the myDoSomethingAfter function.
