  3. Symbol Creation for the entire library
  • Replies 7
  • Subscribers 150
  • Views 21482
kenambo
kenambo over 11 years ago
Hi all
I want to create symbols for all the schematics in a library. i know how to create a symbol for a cellview.
I dont know how to get schematics oneby one from a library and converts schematics into symbol.
Please give me some suggestions or ideas.
  • theopaone
    theopaone over 11 years ago
    There is information on this in the Schematic Editor L User Guide. Explore the sections on Automatically Creating CellViews, Text-To-Schematic Generator, and Symbol and Simulation Library Generator.
    There may already be code written by others out there.
    Ted
  • kenambo
    I just found some commands from which i wrote code for generating symbols for a whole library.
    procedure(libSymCreation(libname)
    libId=ddGetObj(libname)
    foreach(cell libId->cells
        foreach(view cell->views
             case(view->name
                    ("schematic"
                  if(dbOpenCellViewByType(libId->name cell->name "symbol")
      then
    printf("symbol already exists \n")
    else
                        pinList=schSchemToPinList(libId->name cell->name "schematic")
                        schPinListToSymbol(libId->name cell->name "symbol" pinList)
              (t
    Where libname is the library where the cells are placed.
    Thanks.
  • theopaone
    Good job, Great initiative.
    You may want to close your open cellViews to keep within the system limits for number of open files.
  • theopaone
    Rather than use dbOpenCellViewByType, you can use ddGetObj.
    if( ddGetObj( libId~>name cell~>name "symbol") then
    This checks for the existence of the symbol view directory without opening it.
    Ted,
    Opening a cellView doesn't keep the file handle open, so it wouldn't run out of file descriptors. However, it does mean that you are keeping them all in memory - so it's always a good idea to close anything you open to allow it to purge anything no longer needed.
  • theopaone
    You are right again, Andrew, once the cellView data is read into VM, the OA file is no longer open.
  • kenambo
    Thanks guys..
    i will update my code as per your suggestions...
