  3. Last Week at Fidelity CFD
John Chawner
John Chawner
CFD
Marine Engineering
thermal management
turbomachinery
webinars
Pointwise
Computational Fluid Dynamics
Fidelity CFD
Mesh Generation
cooling
Meshing
13 Feb 2023 • 5 minute read
Let's take a look at what has happened at Cadence Fidelity CFD recently. It's actually been a couple of weeks since we last gave you an update, so there's a lot of cool stuff.
From the Blogs
Opra Turbines: Gas Dispersion Analysis and Explosion Protection of a Gas Turbine
CFD simulations are an integral part of OPRA’s design process. Simulations are used to analyze and optimize flow within various areas, including combustion, turbomachinery, and gas dispersion analysis. OPRA has been exploring using the open-source CFD to complement commercial CFD software packages. A good mesh is essential for performing a CFD analysis, especially hex-dominant meshes. While various open-source meshing tools are available, they can be hard to use for real (industrial) geometries because of limited geometry import, non-intuitive operation, and limited documentation. This is where Fidelity Automesh shines. Read more.
Limitless Export Formats with Fidelity Pointwise CAE Plugins
Fidelity Pointwise can export meshes to over four dozen native CFD and CAE file formats. But even that's not enough. This is why Pointwise includes a CAE Export Plugin SDK that allows anyone to add to the software mesh export to any format. All it takes is a little programming, perhaps starting from some of the plugin source code we freely share, and you drop the plugin into a folder, and the next time Pointwise starts, your flow solver appears in the UI. Read more.
Hull Shape Optimization Reduces Ferry Fuel Consumption by 13%
With climate challenges top of mind, the International Maritime Organization (IMO) is taking an ever more active role in establishing a more sustainable global fleet. The IMO2023 regulations have entered into force since November 2022. They are set for the shipping industry to meet the target of reducing carbon emissions from international shipping by 40% by 2030 and 70% by 2050 versus the 2008 levels. CFD can play an active role in reaching those challenging goals by providing an accurate understanding of ship performance and showing us where and how to optimize their designs for minimal fuel consumption. Read more.
On-Demand Webinar - How to Efficiently Mesh Complex Blade Tips with High Accuracy
In this on-demand webinar, watch how we mesh a turbine blade with complex tip geometry in the Cadence Fidelity CFD Platform, capturing all its intricate geometric details for both fluid and solid domains. We complete the analysis with a conjugate heat transfer (CHT) simulation using Fidelity CFD’s pressure-based solver that can simultaneously tackle the solution of momentum, continuity, and energy equations. Read more.
Electronics Cooling: The Past, the Present, and the Future
Electronics cooling technology has been in place since the 1960s, but as customers aspire for high-power electronic gadgets, new thermal management techniques become prerequisites for accommodating these needs. There is a lot to learn from the past, apply those learnings with necessary modifications to the present, and predict the needs of future cooling systems. Read more.
Events
CadenceCONNECT CFD - 19 Apr
CadenceCONNECT CFD will be held on 19 April at the Santa Clara Convention Center. The event will feature presentations from your industry colleagues that will offer solutions for today’s fluids analysis challenges that impact the design and development of tomorrow’s products. CadenceCONNECT CFD brings users, developers, and industry experts together to connect, share ideas, and inspire design creativity. Attend and enjoy a captivating keynote and engaging user presentations and interact with CFD experts, peers, and our sponsors. CadenceCONNECT CFD will be hosted alongside CadenceLIVE Silicon Valley. Your registration will allow access to both events. Register today.
The call for presentations remains open until 17 February. Email your abstract to your Cadence CFD contact ASAP.
Live Webinar: Simulating Fluid-Structure Interaction (FSI) with Fidelity - 28 Feb
Fluid-Structure Interaction (FSI) modeling is a fundamental step in the design process of turbomachinery. Highly variable pressure loads and temperature gradients affect not only efficiency and performance but also the structural integrity of blades. FSI simulations are a challenging activity where mesh deformation techniques, complex modeling, and flow unsteadiness all come into play. In this CadenceTECHTALK, we will introduce the FSI simulation capabilities of the Cadence software, describe the modeling of geometry deformation, and understand its effect on the fluid field. Register today.
Live Webinar: Self-Propulsion CFD Simulations: Get Them Right and Fast - 23 Feb
Based on many years of experience working closely with our customers, Cadence offers many dedicated features to achieve highly accurate simulations with minimum turnaround time. In this webinar, we explore some of the main benefits, and through a live demonstration, we will show you how to set up the simulation in the dedicated wizard within the Fine Marine interface. Register today.
Videos
Fidelity Pointwise: Adjust Connector Dimension Based on Curvature
Learn how to automatically adjust connector dimension and the distribution of the grid points by taking into account the curvature of the underlying curve. With the “Curvature” option from the “Grid, Dimension” command, you can use angular and chordal deviation tolerances to enforce grid resolution where there is high curvature. Watch now.
Fidelity CFD: All About Geometry Import
Learn the best way to import files into Fidelity, from serial to parallel import, tessellation options, legacy Autogrid project import, and much more. Watch now.
Fidelity Pointwise: 2022.2 New Features - Grid, Elevate
Learn how to export high-order meshes in Fidelity Pointwise. With the release of Fidelity Pointwise 2022.2, the new Elevate task under the Grid menu consolidates all of the high-order elevation and export controls into a single interface, offers performance improvements over previous versions, and adds the ability to export mixed-order meshes. Watch now.
Don't Miss Anything
  • Subscribe to the Cadence CFD blog with the Subscribe By Email button at the top of this page. You'll get an email whenever something new is posted.
  • Subscribe to CFD Innovators Digest, our biweekly summary of news that goes directly to your email inbox.
  • Take a Free Trial of any (or all) components of the Fidelity CFD portfolio.
