  3. Analog Design Resonance: Quick and Efficient Regression…
stacyw
stacyw
ADE Explorer
ADE
ADE Assembler
Analog Design Resonance: Quick and Efficient Regression Scripts–Now Possible with ADE Explorer and ADE Assembler
1 Aug 2016 • 3 minute read
The new Virtuoso ADE product suite is packaged with a lot of easy-to-use, productivity-enhancing, and robust features including a new set of SKILL functions that make it easy to write and deploy efficient regression scripts.The new functions can be used with both Virtuoso ADE Explorer and Virtuoso ADE Assembler, and provide ease and efficiency in setting up regression flows from batch mode. These functions can be used only for the maestro cellviews, thus their names are prefixed with mae. You can have a quick look at the list of available functions in Cadence SKILL API Finder.
Image of Virtuoso ADE SKILL API Finder
Note: To open the Cadence SKILL API Finder window, click Tools -> Finder in the CIW.
Let’s look at some of the benefits that these new functions provide.
Ease of Use
The mae functions are comprehensive, that is, each function takes care of most of the required elements itself. Thus, you can complete an action by using fewer commands as compared to an ADE XL script. In addition, the new functions always work in context of the current session and setup database, so you don't need to provide these values as arguments unless you are working with multiple sessions. This makes scripting much simpler!
For example, if you need to load a maestro cellview, enable a test or a set of corners, run simulation, and save results, you can do this by using a just few commands, as shown below.
session=maeLoadSetup("myLib" "myCell" "myView" ?mode "a")
; loads the active setup for the given cellview
maeSetSetup(?test '("test1") ?enabled t)
; enables test 'test1'
maeSetSetup(?corners '("corner1" "corner2") ?enabled t)
; enables two corners
historyName=maeRunSimulation()
maeExportOutputView(?fileName "simResults.csv" ?view "Detail")
; exports the simulation results to a csv file
exit()
Compatibility with the Existing SKILL Functions Used for ADE L and ADE XL
There are mae functions for most of the common actions, but if there is any specific action for which an mae function is not available, you can use the existing axl or asi functions. For example, to find the parasitic run mode set in the given session, you can use the axlGetParasiticRunMode function and provide the setup database for the maestro session as an argument to that.
Similarly, you can edit the model file for a test using the handle to the maestro test in the asiAddModelLibSelection function, as shown below.
sess=maeLoadSetup("opamp090" "full_diff_opamp_AC" "maestro" ?mode "a")
=> "fnxSession0"
Example 1:
handleSDB=axlGetMainSetupDB(sess)
=> 1001
axlGetParasiticRunMode(handleSDB)
=> "No Parasitics/LDE"
Example 2:
testnames=maeGetSetup()
=> ("AC" "TRAN")
testHandle=maeGetTestSession(car(testnames))
=>stdobj@0x21989b60
asiAddModelLibSelection( testHandle "../models/spectre/gpdk090.scs" "NN" )
=> t
Ability to Save Scripts Directly from the User Interface
Another interesting feature is that if you have configured the setup, including the tests, outputs, run options, etc., in the Virtuoso ADE Explorer or Virtuoso ADE Assembler user interface, then you can save that in a script by running the maeWriteScript command from the CIW. Yes, that's a quick way to create a script, but that's not all! There's an additional benefit—since the saved script uses a reference to the cellview, if you make any change in the cellview later, the script will always be synchronized with it. No need to update the script to reflect the changes in the setup. Now, doesn't that sound useful?
More Info
For more details about these functions, refer to the following collateral:
  • Introduction to MAE APIs in Assembler (RAK on Cadence Online Support--requires login)
  • Virtuoso ADE Explorer and ADE Assembler SKILL Reference (requires login)
TeamADE
