  3. Art of Analog Design Part 7: Mismatch Tuning
Art3
Art3
mismatch tuning
Monte Carlo analysis
DC Mismatch
3 Nov 2017 • 4 minute read
In days of future past, we looked at DC mismatch analysis and compared it to Monte Carlo analysis for analyzing the effect of device mismatch on the offset voltage of a differential amplifier. We found that DC mismatch does provide good estimates of the effect of mismatch with the limitation that the offset voltage has a Gaussian distribution. Since DC mismatch analysis only needed a single simulation to generate an estimate, we can use it for design exploration. For example, when looking for the worst-case corner for offset voltage, we can use DC mismatch analysis to accelerate simulation time.
Suppose that we wanted to find the device size that meets our design specification for offset voltage. Let’s start with the same differential amplifier and assume that the offset voltage should be 1mV. How can we find the optimum gate width for this offset voltage 1sigma value? One option would be to perform DC mismatch analysis and sweep the n-channel transistor gate width. Let’s set a specification of a target offset voltage of 1mV and look for the gate width that will meet our offset voltage specification.
Figure 1: Parametric Sweep of Device Size vs. Offset Voltage
In this case, we swept the number of fingers for input pair and can see that the we can significantly reduce the area without compromising the offset voltage of the amplifier.
There is actually one alternative to the parametric sweep approach for tuning offset voltage. We can use mismatch analysis to perform the same task. In the Mismatch Contribution window, you can click on the Mismatch Tuner icon, see the red box on Figure 2.
Figure 2: Using Mismatch Tuner to Size Transistors for Offset Voltage
When you click on the Mismatch Tuner icon, you get slider bars that you can adjust and the results in the Contribution Analysis window are updated. What we see here is that by reducing the gate width of the input transistors by 60%, then the offset voltage is 1mV. This result is consistent with the results of the parametric sweep of DC mismatch analysis. We can reduce the size of the input transistors by 60% and still meet our objectives for offset voltage.
 So, which method should I use? If all you are interested in is offset voltage of a linear analog circuit, then using DC mismatch with parametric sweep may be sufficient. However, in most other cases, this option is not available. Consider the dynamic comparator, it does not have a quiescent operating point so we can’t use DC mismatch to estimate the input stage scaling. In this case, mismatch tuning can be used. Suppose you need to make a choice to achieve a 500uV offset voltage, you can either scale the devices or add additional circuitry to calibrate out the offset. After running Monte Carlo analysis, see figure 3, the current offset voltage of the comparator is about 1mv, good but not good enough to meet the target.
Figure 3: Dynamic Comparator Offset Voltage
So, let’s try using the mismatch tuner, see Figure 4. In this case, we see that we need to increase the device size by 4x to reduce the offset voltage level to an acceptable level. Based on this result, the designer needs to decide which approach to take: scaling the input devices, or adding an offset calibration, to better optimize area and power. So, we can use mismatch tuning to give us insight into how variation impacts offset voltage. Another use case to consider is suppose you have several parameters to trade-off: offset voltage, power supply rejection ratio, common-mode rejection ratio, and bandwidth. In this case, mismatch tuning allows you to envision interaction between device scaling and multiple parameters. So, while the two approaches overlap, using the mismatch tuner is a more general solution for analyzing the effect of mismatch on circuit performance.
Figure 4: Dynamic Comparator Offset Voltage Mismatch Tuning
One thing to keep in mind when using either dc mismatch analysis or mismatch tuning is that these techniques rely on mathematical techniques to estimate the effect of mismatch. These results should be verified with Monte Carlo analysis. In this case, after using mismatch tuning the results were checked. Before sizing the offset voltage was 938uV. Mismatch tuning suggested that by increasing the device size by about 4x, the offset voltage would be reduced to 480uV. Monte Carlo analysis shows that the actual offset voltage after tuning was 406uV, see figure 5.
Figure 5: Dynamic Comparator Offset Voltage Monte Carlo Results after mismatch tuning
Over the last two blogs, we have looked at DC mismatch analysis. In the previous blog, we compared the results from dc mismatch analysis to Monte Carlo analysis as a tool for estimating offset voltage. Then in this blog we looked at using dc mismatch as a design tool to improve our design. In the next blog, we will take a similar look at AC mismatch analysis.
