  3. From Log to Library: Debugging Characterization with Liberate…
Rajshekharayya
Rajshekharayya
modeling.log
client.log
Cadence Certification
library characterization
characterization flow
Library Modeling
bolt
Cadence training
char.log
LiberateTrio
assemblyjob.log
simulationjob.log
simulation.log
Characterization Logs
Liberate
MPVT characterization
assembly.log
characterization debugging flow
liberate debugging flow
Custom IC
From Log to Library: Debugging Characterization with Liberate Trio
16 Nov 2026 • 4 minute read
A Practical, Stage-Based Approach to Finding Characterization Failures Faster
You start a library characterization run and return expecting a completed .lib file, only to find that it is missing. Where did the flow fail? Was the issue in job distribution, preprocessing, circuit simulation, table generation, or final library modeling?
The fastest way to debug a failed characterization run is to identify the stage that failed, then inspect the log associated with that stage.
Why Structured Debugging Matters
Liberate Trio characterization operates through multiple stages, including flow control, job management, preprocessing, circuit simulation, data assembly, and library modeling. Dedicated logs provide visibility into these different parts of the flow, helping narrow the investigation to the stage associated with the failure.
Practical Debugging Journey
Use the overall characterization flow to identify where the failure appears, then move directly to the log associated with that stage. The Characterization Debugging Flow training provides an overview of the end-to-end process before the individual log-analysis trainings go deeper.
Training: Characterization Debugging Flow.
1. Start with char.log: Understand the Overall Run
char.log provides the master view of the characterization run. It captures the execution flow, tracks processed cells and PVTs, and reports the final PASS or FAIL status.
Look here when investigating:
  • Flow aborts
  • Missing cells
  • Incorrect PVT definitions
  • Licensing issues
  • TCL or script errors
Training: Liberate Trio MPVT Main char.log Analysis and Run Summary.
2. client_<N>.log: Investigate Job Execution
When jobs fail to start, become stuck, or show no simulation activity, move to the client logs. These logs capture how jobs are distributed across worker machines and track packet or Bolt client activity.
  • Jobs do not start
  • Jobs appear stuck
  • No simulation activity is visible
Training: Liberate Trio MPVT Bolt Scheduler client_(N).Log Analysis.
3. countingjob_*.log: Validate Preprocessing
The counting-job logs provide visibility into preprocessing activities, including timing-arc discovery, vector generation, effective-parameter selection, and coordination of characterization tasks.
  • Incorrect pins
  • Missing timing arcs
  • Unexpected vector behavior
Training: Liberate Trio MPVT Preprocessing countingjob.log Analysis.
4. simulationjob_*.log: Diagnose Simulation Failures
Once characterization reaches circuit simulation, simulationjob_*.log becomes the key resource for understanding simulation-related problems and troubleshooting simulator issues.
  • Convergence failures
  • Floating nodes
  • Missing model includes
  • Time-step errors
Training: Liberate Trio MnPVT Simulationjob.log Analysis.
5. assemblyjob_*.log: Examine Table Construction
After simulation, the assembly stage constructs timing, power, and noise tables from the simulation results. assemblyjob_*.log provides visibility into this part of the flow.
  • Dropped arcs
  • Insufficient data
  • Invalid transition ranges
  • Skipped noise tables
Training: Liberate Trio MPVT Assemblyjob.log Analysis.
6. modeling_*.log: Confirm Final Library Generation
The modeling log covers the final stage of characterization, where characterized data is merged into the .lib output. Use it to investigate issues associated with final library generation and to review the final output.
Training: Liberate Trio MPVT Modeling.log Analysis.
Quick Debugging Reference
If you need to investigate…
Start with…
Overall run status, cells, PVTs, licensing, or scripts
char.log
Jobs that do not start, become stuck, or show no simulation activity
client_<N>.log
Missing arcs, pin issues, or unexpected vectors
countingjob_*.log
Convergence or other simulation problems
simulationjob_*.log
Dropped arcs, insufficient data, or table-generation issues
assemblyjob_*.log
Final library generation
modeling_*.log
A Repeatable Debugging Strategy
  1. Identify the failure symptom
    What is missing or unexpected: a job, simulation result, timing arc, table, cell, or final library?
  2. Locate the relevant characterization stage
    Determine whether the problem occurred during execution, preprocessing, simulation, assembly, or modeling.
  3. Inspect the corresponding log
    Use the dedicated log to focus the investigation on that stage.
  4. Trace the flow toward the final output
    Follow the relevant stages through final .lib generation.
From Failure Symptom to Final Library
Debugging characterization becomes much easier when you know where the flow failed and which log explains that stage. Start with the overall characterization flow, identify the stage associated with the failure symptom, and then use the corresponding Liberate Trio log to focus the investigation.
Instead of searching everywhere, use a practical path from the first indication of a problem to the final .lib output.
Training Bytes (Video Channel)
  • Liberate Flow: Characterization Terminology
  • Introduction to Characterization Flow
  • Liberate Characterization: Understanding the char.tcl file
  • Liberate Characterization: Using the template.tcl file
  • Liberate Characterization: Understanding the settings.tcl file
  • Interpreting the Output Database
  • Liberate Debugging Features: Part 1
  • Liberate Debugging Features: Part 2
Online Course
MnPVT Characterization of Standard Cells Using Liberate Trio
Characterizing Standard Cells Using Liberate
Become Cadence Certified
You can become Cadence Certified once you complete the course (s) and share your knowledge and certifications on social media channels. Go straight to the course exam at the Learning and Support Portal.
Note: Some of the above links are accessible only to Cadence customers who have a valid login ID for the Cadence Learning and Support Portal.
  • You will need an email address and host ID in order to sign up.
To stay up-to-date with the latest news and information about Cadence training and webinars, subscribe to the Cadence Training emails. If you have questions about courses, schedules, online, public, or live onsite training, reach out to us at Cadence Training.
Take the Accelerated Way
The faster you finish your online training, the sooner you can claim your Digital Badge. Want to know how accelerated learning works? Our video walks you through the pre-quiz, navigation, and essential features. This is just the beginning. We're regularly adding new Accelerated Learning titles. Accelerated Learning courses are marked with this symbol in our Learning Maps.
Thanks for reading, wishing you faster, smarter characterization ahead.
Rajashekharayya Hiremath
Lead Education Application Engineer
