  3. From Simulation Data to a Clear Story: Meet the Datasheet…
Sai Darshan S N
Sai Darshan S N
Virtuoso Studio
training bytes
Custom IC
ADE Assembler
From Simulation Data to a Clear Story: Meet the Datasheet Interface 2.0
10 Sep 2026 • 4 minute read
You have completed several simulations. Now you need to answer a simple question: Did the design meet its targets?
The information may be spread across tests, variables, corners, plots, and simulation histories. Reviewing each item separately can make an otherwise simple design review feel complicated. That is where the datasheet interface 2.0 becomes useful. It turns simulation information into a structured HTML report that is easier to browse, review, and share.
Why Do We Need a Datasheet?
Imagine that you are validating an amplifier across different operating conditions.
You may need to check:
  • Which test was executed?
  • What variables and parameters were used?
  • Which corners were simulated?
  • Did the results pass the target specifications?
  • Which waveforms need closer attention?
A datasheet consolidates this information into a single navigable report. It can include test information, variables, parameters, corner and model-group details, numerical results, and selected plots. The report is stored with the maestro view in ADE Explorer, ADE Assembler, and ADE Artist, appears in the data view assistant, and can be opened in a browser.
What Makes the Interface Easy to Read?
1. A Summary Before the Details
The results summary presents target, minimum, and maximum values together. Color coding makes the status easy to scan:
  • Green: Pass
  • Yellow: Near
  • Red: Fail
This helps reviewers identify results that deserve attention before opening detailed data.
2. Simple Navigation
Sections in the report are linked, and selecting a test name opens its detailed results. Readers can move from the overall summary to an individual test without manually searching through separate outputs.
3. Context Stays with the Result
The session summary can show test, state, simulator, variable, parameter, corner, and model-group information. This makes it easier to understand not only what the result was, but also which setup produced it.
4. Waveforms When They Matter
The datasheet can include waveforms for selected tests. It also supports open graphs, all graphs, or a saved plotting template. Quickplot data can be used for transient waveform images.
A Quick Real-World View
Suppose one corner produces a result close to the required specification.
Instead of opening several simulation windows, you can:
  1. Notice the yellow status in the Results Summary.
  2. Select the test name.
  3. Review its variables, parameters, and numerical results.
  4. Examine the associated waveform.
  5. Return to the main report and continue reviewing.
The interface helps turn a large collection of simulation data into a short investigation path.
The video below gives you a detailed overview of the new datasheet interface.
  The New Datasheet Infrastructure
Want to Learn More?
For lab instructions and a downloadable design, enroll in the online training courses of your interest:
  • Virtuoso ADE Explorer and Assembler S2: ADE Assembler and Multi Test Corner Analysis Training
Training is also available as a blended or live class.
Note: Access to some training links is limited. They are accessible only to the Cadence customers who have a valid login ID for the Cadence Learning and Support Portal.
  • You will need an email address and host ID in order to sign up.
If you have questions about courses, schedules, online, public, or live onsite training, reach out to us at Cadence Training.
Become Cadence Certified
 Cadence Training Services is now offering digital badges for its training courses. These badges indicate your proficiency in a specific technology or skill, allowing you to validate your expertise to potential employers or managers. You can easily add these digital badges to your email signature or social media profiles like Facebook or LinkedIn to highlight your skills and expertise. To become Cadence Certified, you can find additional information here. Go straight to the course exam at the Learning and Support Portal.
Training Bytes (Video Channel)
Virtuoso ADE Assembler (Video Channel)
 Online Course
"Knowledge Booster Training Bytes" is an online journal that provides information about Cadence Training videos, online courses, and upcoming webinars that are available on the Cadence Learning and Support portal. This blog category offers direct links to these videos, courses, and other related materials on a regular basis.
Sai Darshan S Nishani
Sr. Education Application Engineer
