  3. How Do You Ensure the Reliability of Your Design in Virtuoso…
Niyati Singh
Niyati Singh
blended
blended training
relxpert
Reliability Report
learning
training
reliability options
Cadence training
digital badges
training bytes
Cadence certified
Virtuoso Video Diary
reliability analysis
online training
Custom IC
reliability
How Do You Ensure the Reliability of Your Design in Virtuoso Studio?
2 Jun 2024 • 3 minute read
Designers have long recognized the need to analyze the reliability of ICs. Two commonly used approaches for performing reliability analysis include calculating the change in device degradation and relying on safe operating checks in circuit simulators.
With the advent of the ever-increasing use of ICs in mission-critical applications, the need for reliable reliability analysis has become of paramount importance. Over the years, you have been using reliability analysis in Virtuoso ADE Assembler and Virtuoso ADE Explorer to measure and review aging effects, such as device characteristic degradations, model parameter changes, self-heating effects, and so on.
Reliability analysis can be performed using two modes: Spectre native and RelXpert. The reliability analysis analyzes the effect of time on circuit performance drift and predicts the reliability of designs in terms of performance. In ADE Assembler, you can run the reliability simulation for fresh test (when time is zero), stress test (to generate degradation data), and aged test (at specific intervals, such as one year, three years, or 10 years). In the stress test, extreme environmental conditions are used to stress devices before aging analysis.
The following figure shows the reliability simulation flow.
The Reliability Options form has the following four tabs:
  • Basic: Enables you to specify analysis type, aging options, start and stop time of reliability simulation, and options related to device masking, degradation ratio, and lifetime calculation.
  • Modeling: Enables you to choose the modeling type you want to use during reliability simulation.
  • Degradation: Enables you to specify the options to print device and subcircuit degradation information into a .bt0 file.
  • Output: Enables you to specify the degradation reports to be generated and methods to filter degradation results in the reports.
While the Basic and the Output tabs are used by design engineers, the Modeling and the Degradation tabs are primarily used by model developers.
Reviewing degradation reports in text or XML formats can be a tiresome exercise because degradation data can be large and can contain a large number of instances due to advanced technology nodes and post-layout simulations. For you to work effectively and interactively with these reports, the new reliability report is based on the SQLite database, which adds the benefit of improved performance and capabilities of sorting and filtering reliability data using SQLite operators.
As they say, watching this in action might help you more than reading about it, so please take a look at our Training Bytes video channel, which offers many helpful videos on how to run Reliability Analysis in Virtuoso Studio.
All the related videos are linked together in a channel so that you can easily access and watch as many as you like.
Want to Learn More?
For lab instructions and a downloadable design, enroll for the online training courses of your interest on
Reliability Analysis in Virtuoso Studio vIC23.1 (Online)
 Training is also available as "Blended" or "live" class.
Digital Badge Available
You can become Cadence Certified once you complete the course (s) and share your knowledge and certifications on social media channels. Go straight to the course exam at the Learning and Support Portal.
Note: Some of the above links are accessible only to Cadence customers who have a valid login ID for the Cadence Learning and Support Portal.
  • You will need an email address and host ID in order to sign up.
If you have questions about courses, schedules, online, public, or live onsite training, reach out to us at Cadence Training.
   Training Bytes (Videos)
Virtuoso ADE Explorer Graphical User Interface
What is the need for Reliability Analysis? (Video)
   Blogs
Come Join Us and Learn from the Cadence Training Offerings
It’s the Digital Era; Why Not Showcase Your Brand Through a Digital Badge!
  Online Course
Knowledge Booster Training Bytes is an online journal that relays information about Cadence Training videos, online courses, and upcoming webinars that are available in the Learning section of the Cadence Learning and Support portal. This blog category brings you direct links to these videos, courses, and other related material on a regular basis.
Niyati Singh
