  3. Keeping Your Circuit in Tune: Sensitivity Analysis and Circuit…
stacyw
stacyw
Variability Aware Design
ADE GXL
worst case corners
optimization
statistical corners
Variation
Keeping Your Circuit in Tune: Sensitivity Analysis and Circuit Optimization
21 Apr 2014 • 4 minute read
Anyone who has ever played a musical instrument knows how hard it can be to keep the instrument in tune when subjected to variations in weather conditions. Heck, in 2009, Yo-Yo Ma and friends (sorry, he gets top billing because I used to play the cello) pantomimed their performance at the Presidential Inauguration because their instruments wouldn't function properly in the frigid temperatures. Guess they didn't want to risk sounding like my seventh-grade orchestra in front of that large an audience.
Well, we've been talking a lot in this blog recently about the problems caused by the effects of variation on circuit design, and the risks of being "out of tune" can be just as great when it means your chip is late or doesn't work properly.
  • How to sort through hundreds of combinations of PVT corners to find the ones that really matter
  • How to efficiently analyze and design across statistical process and mismatch variation
  • How to smoothly migrate a design from one process node to another while maintaining circuit performance
  • How to quickly identify which parts of the circuit to tweak so statistical mismatch effects won't throw your design out of spec
Today we're going to talk about some of the features available in the Virtuoso Analog Design Environment GXL (ADE GXL) to help you tune your circuit to overcome the effects of variation on circuit performance. Let's start by putting things in the context of an overall flow that looks like this:
Setup and Corner Creation
The basic idea here is that you start with a test setup in ADE XL, which can consist of multiple testbenches, each with a set of output measurements and design specifications. Then you add the relevant corners, which will cover the limits of the design performance across which you need to optimize. These can be your standard PVT corners, they can be a critical subset of corners generated using the ADE GXL Worst Case Corners analysis, or they can be statistical corners generated from a Monte Carlo analysis to capture 3-sigma or other outlying statistical behavior for each of your design specifications.
Parameterization
One of the keys to getting the most out of the circuit-tuning capabilities in ADE XL and ADE GXL is device parameterization. I've written about this feature before, but to recap, the Variables and Parameters Assistant in ADE XL allows you to create parameters for any device properties and vary them at will without having to edit the schematic. You can also incorporate critical device matching and ratioing relationships.
The "Create Parameter Range" option will automatically create a +/-% range on any parameters, which makes sensitivity analysis and optimization a snap.
Sensitivity Analysis in ADE GXL allows you to get a good idea of the criticial devices in your circuit and their effects on design performance. With only a few targeted simulations, you can find out which devices in your circuit have the most impact on each of your design specifications, as well as how changing a device size whether changing a device size to improve one spec will adversely change the other specs.  Device parameterization makes it quick and easy to evaluate "what-if" scenarios until your desired performance is achieved.
Local and Global Optimization
The optimization algorithms in ADE GXL have been proven within our customer base for many years. The optimizer works across all the multiple testbenches, specifications, and corners you already have set up, including the worst-case PVT and statistical corners you have defined to capture the extreme boundaries of your circuit behavior. Device parameters are intelligently varied over the ranges you have defined until all design specifications have been met. Simulations are distributed using ADE XL's job distribution system to maximize the efficiency of the analysis.
ADE GXL provides four local optimization algorithms: BFGS (recommended for most common analog circuits), Conjugate Gradient, Brent-Powell, and Hooke-Jeeves. Use these when you have a reasonable degree of confidence in your initial circuit starting point values. If you aren't sure of your starting point, use Global Optimization, which will perform a much broader exploration of the design space to find viable circuit solutions.
Several additional optimization-based run modes are available, including Size Over Corners to efficiently optimize over a large number of corners and Improve Yield, which combines Monte Carlo analysis and automatic statistical corner creation with iterations of circuit optimization to center your design within statistical process and mismatch variation.
Verification
"The proof of the pudding", as they say, "is in the eating," so the final step in our big red PowerPoint SmartArt arrow above is to verify the results of the circuit tuning. This may involve running a final simulation across all PVT corners or a final Monte Carlo analysis to verify the optimized design can overcome the effects of all types of variation.
