  3. Knowledge Booster Training Bytes - Virtuoso Pin-To-Trunk…
Sandhya P S
Sandhya P S
custom/analog
Virtuoso Space-based Router
VSR
cadence
Routing
Automated Device-Level Placement and Routing
Rapid Adoption Kit
analog
training
Layout Suite
Cadence training
digital badges
Layout
cadenceblogs
ICADVM20.1
Cadence Education Services
online training
RAKs
Virtuoso Layout Suite
Custom IC
IC6.1.8
Virtuoso Layout Suite XL
Knowledge Booster Training Bytes - Virtuoso Pin-To-Trunk Routing
28 Sep 2022 • 4 minute read
 knowledge booster
Are you still using the manual method for Pin-to-Trunk Routing in your design?
The following GIF demonstrates how the Pin-to-Trunk feature works and enhances your layout productivity.
In this blog, let's understand the basics of the Virtuoso Pin-to-Trunk Routing feature and see how it improves routing in your design.
What is Pin-to-Trunk Routing?
The Pin-to-Trunk routing style is used to connect an individual pin to the trunk. You can explore Minimum Spanning Tree (MST) and Pin-to-Trunk style routing, execute the route with default look-up option, trunk trimming, Via setting, Block level routing, Finish Trunk Option, Layer stitching and DRD compactor option.
All the Pin-to-Trunk related videos are linked together in a channel so that you can easily access and learn what you want to.
The Pin-to-Trunk videos in the channel explain how to:
  • Compose the trunk when changing settings from Minimum spanning tree to Pin-to-Trunk routing
  • Use dimming options which is helpful in interactive routing
  • Execute the default look-up option for automatic route using the width of pins
  • Execute trunk trimming without trimming the vias
  • Use Via configuration when connecting to minimum width trunks by using the option “via enclosure and cut direction”
  • Increase your layout productivity using improved routing functionality aimed at block-level interconnect
  • Use MInimum Spanning Tree style Routing with the default setting using Virtuoso Pin to trunk routing
  • Route between blocks by setting various options in the automatic router options form
  • Use the Finish Trunk command to automate interactive Pin-to-Trunk routing
  • Quickly route a bus interactively using the layer stitching bind key along with the Finish Trunk bind key
  • Compact wires to the target with the minimum spacing rule using the DRD compactor with a new bind key
  • You will need an email address and host ID in order to sign up.
If you have questions about courses, schedules, online, public, or live onsite training, reach out to us at Cadence Training.
Become Cadence Certified
Cadence Training Services now offers digital badges for this training course. These badges indicate proficiency in a certain technology or skill and give you a way to validate your expertise to managers and potential employers. You can highlight your expertise by adding these digital badges to your email signature or any social media platform, such as Facebook or LinkedIn. To become Cadence Certified, you can find additional information here. Go straight to the course exam at the Learning and Support Portal.
  Training Bytes (Videos)
Virtuoso layout Design Basics
 Rapid Adoption Kits
IC6.1.8 : Pin To Trunk Block-Level Routing
   Online Courses
Virtuoso Layout Design Basics
Virtuoso Layout Pro: T5 Interactive Routing (XL)
Virtuoso Layout Pro: T6 Constraint-Driven Flow and Power Routing
Virtuoso Connectivity-Driven Layout Transition
SKILL Language Programming Introduction
Advanced SKILL Language Programming
Knowledge Booster Training Bytes is an online journal that relays information about Cadence Training videos, online courses, and upcoming webinars that are available in the Learning section of the Cadence Learning and Support portal. This blog category brings you direct links to these videos, courses, and other related material, on a regular basis.
Sandhya P S
