  3. Knowledge Booster Training Bytes – Spectre Fast Monte Carlo…
Niyati Singh
Niyati Singh
blended
Spectre FMC Analysis
learning
training
Cadence training
digital badges
training bytes
Cadence certified
Virtuoso Video Diary
online training
Knowledge Booster Training Bytes – Spectre Fast Monte Carlo Analysis
10 Dec 2023 • 2 minute read
The Spectre FMC Analysis uses advanced statistical and machine learning (ML) techniques to achieve the right statistical accuracy with the minimum number of Monte Carlo simulations. It works with the Spectre X and Spectre APS Simulators and allows you to distribute Monte Carlo simulation workloads to increase throughput.
It enables fast and comprehensive design space exploration using Monte Carlo simulations of complex analog, RF, I/O, mixed-signal blocks, memories, standard cells, and bit cells while maintaining necessary statistical accuracy. The Virtuoso ADE Product Suite can also be leveraged for distributed processing of Monte Carlo simulations across a compute farm or cloud.
You can run the tool from the command line or from Virtuoso ADE Suite to verify complex I/Os, AMS and RF blocks, and memories. Spectre FMC Analysis’ ML-based technology enables fast exploration and learning of a very large sample space. This allows the designers to quickly identify the worst-case samples to avoid design failures.
As they say, watching this in action might help you more than reading about it, so please take a look at our Training Bytes video channel, which offers many helpful videos on how to launch and use the Spectre FMC.
All the related videos are linked together in a channel so that you can easily access and watch as many as you like.
Want to Learn More?
For lab instructions and a downloadable design, enroll for the online training courses of your interest on Spectre FMC in Virtuoso ADE vIC23.1 (Online). The training is also available as "Blended" or "live" class.
Digital Badge Available
You can become Cadence Certified once you complete the course (s) and share your knowledge and certifications on social media channels. Go straight to the course exam at the Learning and Support Portal.
Note: Some of the above links are accessible only to Cadence customers who have a valid login ID for the Cadence Learning and Support Portal.
  • You will need an email address and host ID in order to sign up.
If you have questions about courses, schedules, online, public, or live onsite training, reach out to us at Cadence Training.
 Training Bytes (Videos)
Virtuoso ADE Explorer Graphical User Interface
 Blogs
Come Join Us and Learn from the Cadence Training Offerings
Do you want to Flaunt your Expertise? Grab the Digital Badge Today!
 Online Course
