  3. Large-Signal Analyses Using HB and Shooting Newton Methods…
Pratul Nijhawan
Pratul Nijhawan
blended
blended training
RF Simulation
Cadence blogs
Spectre RF
learning
training
Cadence training
digital badges
training bytes
Spectre
learning map
RF design
online training
Custom IC
Large-Signal Analyses Using HB and Shooting Newton Methods in SpectreRF Option
9 Nov 2025 • 4 minute read
In the realm of RF and analog design, understanding how circuits behave under real-world, nonlinear conditions is critical. Whether you're designing power amplifiers, mixers, or oscillators, large-signal analysis is the key to ensuring performance, stability, and compliance.
The SpectreRF option, Cadence’s industry-standard RF simulation engine, offers two powerful methods for large-signal analysis:
  • Harmonic Balance – A frequency-domain technique.
  • Shooting Newton – A time-domain technique.
Each method has unique strengths and is tailored for different types of circuits, making them indispensable tools for RF and analog designers.
What Are Harmonic Balance and Shooting Newton Methods?
Method
Domain
Best for
Use case scenarios
Harmonic Balance (HB)
Frequency
RF and millimeter wave circuits
  • Single tone analysis (Low-Noise Amplifier (LNA), Power Amplifier (PA), etc.)
  • Multitone analysis  (mixers)
  • S-parameter data
  • Transmission lines
Shooting Newton (SN)
Time
Analog and digital circuits
  • Single tone analysis (LNA, PA, etc.)
  • Dynamic transient waveforms (dynamic comparators, sample & hold, switched capacitors)
Key Large-Signal Analyses Within Harmonic Balance and Shooting Newton
  • Periodic steady-state calculation
    • Purpose: Analyze small-signal characteristics of a circuit: noise, stability, transfer function.
    • Both Harmonic Balance and Shooting Newton are powerful solutions for calculating the periodic steady-state.
    • The details of the circuit implementation determine which method to use.
  • Harmonic distortion
    • Purpose: Analyze harmonic content and waveform distortion.
    • Both Harmonic Balance and Shooting Newton are powerful solutions for analyzing compression.
  • Intermodulation distortion (IP3)
    • Purpose: Measure linearity via third-order distortion.
    • Harmonic Balance: Generally preferred for analyzing intermodulation distortion.
    • Shooting Newton: Useful for circuits with feedback or biasing complexity.
  • Gain compression (P1dB):
    • Purpose: Identify when amplifier gain drops by 1 dB.
  • Oscillator analysis
    • Purpose: Simulate steady-state, and phase noise response.
  • Load pull
    • Purpose: Evaluate performance across load impedances.
    • Harmonic Balance: Supports fundamental and harmonic load and source pull analysis.
Introducing the Comprehensive Training on Large-Signal RF Analyses Using Harmonic Balance and Shooting Newton
This training provides a hands-on understanding of Large-Signal analyses using both Harmonic Balance and Shooting Newton methods within the SpectreRF option. You’ll learn:
  • When and why to choose Harmonic Balance and Shooting Newton based on circuit behavior.
  • How to simulate and interpret key RF metrics like P1dB, IP3, Load Pull
  • Practical workflows for analyzing LNAs, mixers, oscillators, and power amplifiers.
  • Real-world examples and demo simulations that reinforce each concept.
By the end of the course, you’ll be equipped to confidently apply these techniques in your own RF design projects—bridging the gap between theory and silicon. Whether you're a student, a practicing engineer, or a researcher, mastering these analyses will elevate your ability to design and verify robust RF systems.
For more details, kindly navigate to the training: Large-Signal RF Analyses Using Harmonic Balance and Shooting Newton
How to Enroll
This link gives you more information regarding this course, and the link to enroll: Large-Signal RF Analyses Using Harmonic Balance and Shooting Newton
This course includes slides, audio instruction, and downloadable lab exercises, in line with the lecture content.
Earn Your Badge
  • This training has a Digital Badge You can earn this badge by passing the exam for this course.
  • Training is also available as "Blended" or "live"
You can become Cadence Certified once you complete the course and share your knowledge and certifications on social media channels. Go straight to the course exam at the Cadence ASK and Learning portal.
Note: Some of the above links are accessible only to Cadence customers who have a valid login ID for the Cadence ASK and Learning portal.
Do You Have Access to the Cadence ASK Portal?
  • On the Cadence ASK portal, select Register Now and provide the requested information on the Registration page.
  • You will need an email address and host ID in order to sign up.
  • If you need help with registration, contact ask@cadence.com.
If you have questions about courses, schedules, online, public or live onsite training, reach out to us at Cadence Training.
 Blogs
Come Join Us and Learn from the Cadence Training Offerings
It's the Digital Era; Why Not Showcase Your Brand Through a Digital Badge!
The Year That Was: Knowledge Booster Training Bytes Blog and Video Highlights from 2024
Knowledge Booster Training Bytes – Find and Enroll in a Cadence Online Training Course
 Online courses
Virtuoso Schematic Editor S1: Creating Design Schematics
Virtuoso Schematic Editor S2: Navigating and Capturing Design Intent
Virtuoso ADE Explorer and Assembler S1: ADE Explorer and Single Test Corner Analysis
Spectre Simulator Fundamentals S1: Spectre Basics
Spectre Simulator Fundamentals S2: Large-Signal Analyses
Spectre Simulator Fundamentals S3: Small-Signal Analyses
High-Performance Spectre Simulation
Small-Signal RF Analyses Using Harmonic Balance and Shooting Newton
Product manuals
Spectre Circuit Simulator and Accelerated Parallel Simulator RF Analysis in ADE Explorer User Guide Product Version 25.1
Spectre Circuit Simulator and Accelerated Parallel Simulator RF Analysis in ADE Explorer Workshop Product Version 25.1
