  3. New Spectre AMS Designer Features in Xcelium 26.09
AMSDReleaseTeam
AMSDReleaseTeam
Xcelium 26.09
Dynamic Voltage Supply
Postprocessing
mixed-signal simulation
Verilog-AMS
Analog Operators
SimVision MS
xcelium
18 Nov 2026 • 1 minute read
The Xcelium 26.09 release is now available for download at Cadence Downloads. For information on supported platforms and other release compatibility information, see the README.txt file in the installation hierarchy.
XCELIUM 26.09
Here are some important updates introduced in the Spectre AMS Designer 26.09MAIN release.
  • Checking Verilog-AMS Analog Operators: Use xmvlog to detect invalid argument counts and unsupported Verilog-AMS analog operator usage during compilation. Detecting these issues during compilation helps identify Verilog-AMS syntax issues before simulation. The checks for supported analog operators are consistent with Spectre Verilog-A.
  • Using Environment Variables in Hierarchical Path Definitions: This enhancement extends existing environment variable support and simplifies AMSD control file maintenance by allowing you to use environment variables directly in hierarchical path definitions. For ie card configurations, you can now use environment variables as part of hierarchical path definitions for the vddnet, vssnet, and inst parameters.
  • Simplified SimVision MS Postprocessing Flow: SimVision MS postprocessing no longer requires the -ams_basic_snapshot and -ams_full_snapshot options during simulation. To enable postprocessing mode, use only the -ams_edb option during simulation. After the simulation completes, you can launch SimVision MS in postprocessing mode and access the saved simulation data. This streamlined workflow simplifies postprocessing setup and improves simulation performance and memory usage.
For more details on these and other new or enhanced features introduced in this release, refer to:
What's New in Spectre AMS Designer 26.09
To receive Spectre AMS Designer new feature announcements directly in your mailbox, click SUBSCRIBE in the Subscriptions box.
AMSD Team
