  3. Now Playing: Custom IC Videos-to-Go
stacyw
stacyw
IC 6.1
analog
ADE
ADE-GXL
ADE-XL
IC 6.1.4
27 Sep 2010 • 3 minute read
I wanted to take a brief detour from my usual postings to point out a couple of new delivery mechanisms we're trying out for distributing video collateral -- making better use of some of those toobz on the interwebs.
First, we've made some of the videos in the CIC Video Library at https://support.cadence.com/ available for download.  This way all the users at your site can access the videos at your convenience without having to be logged into Cadence Online Support.
Here's a list of what's available:
Release
(valid from)
Video Topic
Software Area
IC 6.1.4
Constraint Driven Flow in Virtuoso (15 mins)
VSE-XL, VLS-XL, and VLS-GXL
IC 6.1.4
Using Context-Sensitive RMB Menus (9 mins)
Virtuoso Layout Suite XL
IC 6.1.0
The World View Assistant in VSE XL (1 min)
VSE XL
IC 6.1.0
User Interface Configurations in VSE XL (3 mins)
VSE XL
IC 6.1.4
The Stretch command in VSE L (5 mins)
VSE L
IC 6.1.0
The Search Toolbar and Assistant in VSE XL (3 mins)
VSE XL
IC 6.1.0
The Property Editor Assistant in VSE XL (2 mins)
VSE XL
IC 6.1.4
Direct Text Editing in VSE L (1 min)
VSE L
IC 6.1.4
Dynamic Net Highlighting and Probing in VSE L (1 min)
VSE L
IC 6.1.4
The Navigator Assistant in VSE XL (2 mins)
VSE XL
IC 6.1.4
Design Data Access in VSE L (4 mins)
VSE L
IC 6.1.3
Variable and Parameter Sweeps in ADE XL (1 min)
ADE XL
IC 6.1.4
Spec Comparisons in ADE XL (3 mins)
ADE XL
IC 6.1.4
Setting Specifications and Running Simulations in ADE XL (3 mins)
ADE XL
IC 6.1.4
Setting up Multiple Tests in ADE XL (3 mins)
ADE XL
IC 6.1.4
Results Panel Views in ADE XL (1 min)
ADE XL
IC 6.1.4
Incremental Resimulation in ADE XL (2 mins)
ADE XL
IC 6.1.4
Device Instance Parameterization in ADE XL (2 mins)
ADE XL
IC 6.1.4
Monte Carlo Analysis in ADE XL (3 mins)
ADE XL
IC 6.1.4
Creating Datasheets in ADE XL (1 min)
ADE XL
IC 6.1.4
Setting Up and Simulating Corners in ADE XL (4 mins)
ADE XL
IC 6.1.4
ViVA Calculator Integration in ADE XL (1 min)
ADE XL
IC 6.1.4
User Interface Configuration and Advanced Expression Support in ADE L (3 mins)
ADE L
IC 6.1.4
Dependent Expressions in ADE L (5 mins)
ADE L
As if that isn't enough to keep you busy, we've also posted some of the videos on YouTube.  That's right, Cadence has its own YouTube Channel.  Hit the Subscribe button, so the next time you're standing in line at the DMV and feel a sudden need to know how to set up specifications in ADE XL, just pull out that smart phone and take a look.
Stacy Whiteman
