  3. Spectre MDL: Turn Simulation Results into Reusable Meas…
Sai Darshan S N
Sai Darshan S N
Spectre
Custom IC
Spectre MDL: Turn Simulation Results into Reusable Measurements
10 Sep 2026 • 3 minute read
Running a simulation is only half the job. Engineers must also extract useful measurements from the resulting waveforms.
Imagine characterizing an amplifier across different voltages and temperatures. Manually checking gain, rise time, duty cycle, and threshold crossings for every run can become repetitive. Spectre Measurement Description Language, or Spectre MDL, helps automate this work.
What Is Spectre MDL?
Spectre MDL is a scripting and measurement language that works with the Spectre Circuit Simulator and Virtuoso Visualization and Analysis.
It can help you:
  • Create reusable measurement definitions
  • Run simulations in batch mode
  • Pass parameters into measurements
  • Automate sweeps using loops
  • Search for circuit-performance boundaries
  • Evaluate additional measurements from existing simulation results
A Simple Example
An engineer may want to measure the DC gain and zero-dB crossing frequency of an amplifier:
The measurement alias connects an analysis with one or more measurement expressions. It can then be reused in compatible simulation flows.
Why Use Spectre MDL?
Reuse Measurement Logic
Measurements such as gain, rise time, fall time, RMS, duty cycle, phase margin, and threshold crossing can be defined once and reused.
Automate Characterization
The foreach statement supports repetitive simulations and sweeps. The search statement varies a parameter until a specified circuit condition is reached.
Reduce Unnecessary Simulation
The autostop feature can stop a transient simulation after sufficient data is available for the requested measurements.
Measure Existing Results
Postprocessing mode lets you evaluate updated or additional measurements using an existing simulation results database, provided the required signals were saved.
Spectre MDL turns measurement intent into an executable and reusable part of the simulation flow. Instead of repeatedly inspecting waveforms, engineers can automate measurements, sweeps, searches, and postprocessing. For anyone working with Spectre simulation and analog characterization, MDL offers a practical path from waveforms to repeatable results.
Want to Learn More?
For lab instructions and a downloadable design, enroll in the online training courses of your interest:
  • Spectre Simulator Fundamentals S4: Measurement Description Language Training
Training is also available as a blended or live class.
Note: Access to some training links is limited. They are accessible only to the Cadence customers who have a valid login ID for the Cadence Learning and Support Portal.
  • You will need an email address and host ID in order to sign up.
If you have questions about courses, schedules, online, public, or live onsite training, reach out to us at Cadence Training.
Become Cadence Certified
 Cadence Training Services is now offering digital badges for its training courses. These badges indicate your proficiency in a specific technology or skill, allowing you to validate your expertise to potential employers or managers. You can easily add these digital badges to your email signature or to your social media profiles, such as Facebook or LinkedIn, to highlight your skills and expertise. To become Cadence Certified, you can find additional information here. Go straight to the course exam at the Learning and Support Portal.
Training Bytes (Video Channel)
Spectre MDL (Video Channel)
Online Course
"Knowledge Booster Training Bytes" is an online journal that provides information about Cadence Training videos, online courses, and upcoming webinars that are available on the Cadence Learning and Support portal. This blog category offers direct links to these videos, courses, and other related materials on a regular basis.
Sai Darshan S Nishani
Sr. Education Application Engineer
