  3. Virtuosity: Sweeping Multiple Config Views
Arja H
Arja H
Analog Design Environment
ADE Explorer
Explorer
Analog Simulation
ADE
Schematic Editor
Virtuosity
Circuit Design
Schematic
ADE Assembler
18 Sep 2017 • 2 minute read
Before IC6.1.7 ISR10, you could sweep multiple views for only one block in your design. What if you have more than one block that has multiple views that you want to sweep? Well from ISR10 onwards, you can do that.
The flow is similar to the original config sweep flow but you are not limited to only having one CONFIG_SWEEP variable.
Sweeping multiple blocks in a single view
Let's take a look at a simple example. In this schematic view we have 2 blocks, OpAmp and opamp_dc_feedback.
The OpAmp block has three different schematic views, the opamp_dc_feedback block has two different schematic views - these could be other view types such as DSPF, layout, extracted, estimated etc.
In ADE, simply right-click Global Variables and choose Add Config Sweep. The Select Views form pops up, choose the library and cell from the drop-down list and then click on Select to choose which views you want to sweep, as shown in the figure below:
Repeat this for the opamp_dc_feedback block.
Now, you can see the two CONFIG variables in the Data View as shown below. Previously it was limited to only one CONFIG variable.
Remember that handy Run Preview tab? Here, you can see the combinations of sweeps that will be run.
Also notice that there is now a Run column. This allows you to select which points to be run - see the Run Point Selection blog for more information.
Run the simulation and see the results.
  • Blog
    • Run Point Selection
  • User Guide
Note: For more information on Cadence circuit design products and services, visit www.cadence.com.
About Virtuosity
Virtuosity has been our most viewed and admired blog series for a long time that has brought to fore some lesser known, yet very useful software and documentation improvements, and also shed light on some exciting new offerings in Virtuoso. We are now expanding the scope of this series by broadcasting the voice of different bloggers and experts, who would continue to preserve the legacy of Virtuosity, and try to give new dimensions to it by covering topics across the length and breadth of Virtuoso, and a lot more… Click Subscribe to visit the Subscription box at the top of the page in which you can submit your email address to receive notifications about our latest Virtuosity posts. Happy Reading!
Arja Hunkin
