  3. The Art of Analog Design Part 5: Mismatch Analysis I…
Art3
Art3
spectre aps
offset voltage
mismatch analysis
Analog Simulation
ADE
Monte Carlo analysis
Strong Arm latch
dynamic comparator
The Art of Analog Design Part 5: Mismatch Analysis II
13 Oct 2017 • 3 minute read
In Part 4 of the series, we looked at applying mismatch analysis as a design tool. In Part 5, we will continue to look at mismatch analysis by applying the technology  to other types of designs..
The first case we will look at is a circuit without a DC operating point. A dynamic comparator, see Figure 1, doesn’t have a quiescent operating point making it difficult to analyze.
 In this case, the offset voltage is measured using transient analysis. A positive and a negative staircase is applied at the input and the input value which results in the output switching being recorded, the average value of input levels is the offset voltage. To increase the resolution of the offset voltage measurement, the step size needs to be small. In this case, the step size of the staircase ramp is 100mV. A Verilog A module was used as the signal source to generate the staircase, see Figure 2. For more details about measuring dynamic comparator offset Voltage, please see the ADC Verification Workshop Rapid Adoption Kit in Cadence online support.
Looking at the comparator, we would expect that the mismatch of the p-channel input transistors is the primary source of offset voltage.  After the Monte Carlo analysis, we will use scatter plots showing the random variable causing mismatch for three transistors: NM2, NM3, and NM4, see Figure 3a. For the devices in the differential pair, NM2 and NM3, we can see that there is correlation between the offset voltage and the input transistors, the correlation coefficient is r about 0.5. For the current source transistor, NM4, there is no correlation, the correlation coefficient r about 0, between the offset voltage and the transistor’s variation. So, the scatter plots are consistent with our expectations about how the devices are impacted and the statistical variation.
Again, we can see the utility and the limitations of the scatter plot. Qualitatively the scatter plot allows us to visualize the relationship between the inputs, statistical variables, and the outputs measured values. However, it is difficult to extract quantitative information from the results. So, while we can use scatter plots to confirm what we already know, they don’t really provide any additional information to designers.
We will use mismatch analysis to analyze the relationship between variations on offset voltage. The mismatch analysis results are shown in Figure 4. Again, we see that offset voltage has a non-linear, second-order relationship with the statistical variables. We can also see that most of the variation, 99.935% is accounted for by the mismatch results. We can see that ~90% of the offset voltage is due to the input transistor variation. Mismatch analysis considers the variation at the statistical variable level: NM2.rn2 contributes 30%, NM3.rn2 contributes 29%, NM2.rn1 contributes 17%, and NM3.rn1 contributes 16%. While our naming convention could be more explicit, you can think about the variables as the individual contributions to variation: gate oxide thickness variation and gate length variation. Another observation is that there is another source of offset voltage variation, the cascode transistors, NM0 and NM1. While not significant, it useful to know that mismatch analysis has enough resolution to identify small contributors.
Mismatch analysis provides designers a tool to analyze the effect of mismatch qualitatively and quantatively.
To summarize, the mismatch analysis is a useful tool to analyze the results of Monte Carlo analysis. In this case, we analyzed the effect of variation on a dynamic comparator. Traditionally it is difficult to analyze a dynamic comparator because it is not a linear circuit with a DC operating point. Perhaps more than anything else, the ability to analyze circuits that designers have not been able to analyze in the past is the true value of mismatch analysis.
