  3. Things You Didn't Know About Virtuoso ADE
stacyw
stacyw
Virtuoso IC 6.1.3
10 Sep 2009 • 3 minute read
After delving into lots of new features in the Virtuoso Schematic Editor, the Library Manager and the Help System, I'd like to turn to our old friend ADE (aka Analog Design Environment, or for those of us who've been around awhile, Analog Artist).  ADE is another one of those tools that you're probably using exactly the same way you've always used it because--well, because that's the way you've always used it.  And besides Cadence hasn't done anything new to ADE in years...or have they?
Take a look at the ADE window on your desktop.  I'll bet it's rectangular in shape about 700 pixels wide by 450 pixels high.  Got it right, didn't I?  Well, of course, because everyone knows that if you resize the ADE window, all you get is a bunch of extra blank space.  Guess what, give it a try.  We've now figured out how to resize the window properly so the contents expand to fill the extra area.  The first time I showed that in a demo you could just feel the excitement in the room.  All right, maybe not excitement exactly, but I did hear someone utter an only-slightly-cynical "wow".
So, besides this minor miracle, what other features have we added?
Edit in Place
Well, for starters, you'll notice that you can edit a lot of things in your simulation setup directly from the main window without having go through the menus and open a separate form.  If you want to change the value of a design variable, just select the name and click in the value field to edit it.  No need to do Variables->Edit..., select the name, type the number, click the Change button, then OK the form.  That's about half the number of mouse clicks.
You can also check and uncheck the "Plot" and "Save" checkboxes directly from the main window.
For those items which can't be edited directly in the main window, things are simplified somewhat in that you can double-click on each entry and it will open the correct form entry for that item.   For example,  if you double-click on an output expression or an analysis, the form will come up with the settings for that particular entry.
VAR Parameterization
One really cool "hidden" new capability of ADE is that you can now create and use design variables just about anywhere in your simulation setup.  This is done using what we call VAR syntax.  For example, you can specify the transient analysis stop time by putting VAR("stopTime") in the appropriate field in the Choosing Analyses form.  This will automatically create a design variable which you can change directly from the main window (and use in other places as well).  Similarly, you can parameterize model files and sections, simulator options and many other things.  More information on this useful feature can be found here.
Plot Refresh
You may also notice a new cyclic pulldown at the bottom of the ADE window, just under the Outputs section.  It's labeled "Plot After Simulation" and the choices are "Auto", "Refresh" and "None".  This allows you to control the behavior of your ViVA graph windows when you re-run a simulation.  In the past, if you chose to auto-plot waveforms, any modifications you made to your graph windows were wiped out when you re-ran the simulation.  If you had customized the graph at all, you had to turn off auto-plotting and then manually refresh each graph window after simulation to maintain your customizations.
Now you can select "Refresh" from this new pulldown and your graph windows will refresh with the new simulation data without undoing any modifications you may have made.
Something for the more adventurous user...
A really nice way to back-annotate results from parametric sweeps can be enabled by typing: artEnableAnnotationBalloon(t) in the CIW.  This activates a large "balloon" when you hover your mouse over an instance.  The balloon contains your specified annotation information for the different sweeps of the parametric run.  More information on this can be found in the Virtuoso Analog Design Environment L User Guide under "Annotating Parametric Sweep Results" and a helpful video demonstration can be found here.
ade
Well, that's all for now.  Starting next time...Things You Didn't Know About ViVA!
Stacy
