  3. Training Insights – Virtuoso Spectre Transient Noise
Pratul Nijhawan
Pratul Nijhawan
blended
blended training
ADE Explorer
learning
training
Cadence training
digital badges
training bytes
Spectre
Cadence certified
learning map
Schematic Editor
Cadence Education Services
Custom IC
Schematic
Spectre X Simulator
ADE Assembler
19 Dec 2023 • 3 minute read
This two-day training course focuses on transient noise simulations using the Spectre simulator inside the Virtuoso Analog Design Environment (ADE) Suite. The course is characterized in the following modules:
  • Introduction to transient noise analysis: In this introductory module of the course, you explore topics such as transient analysis, different noise analyses in Spectre, and transient noise analysis. You'll also learn about the computational challenges, the transient noise algorithm, and the typical noise spectrum for a device. Additionally, this module includes in-depth explanations of various parameters used under the transient noise form.
  • Transient noise simulations: After the introductory module, you will learn about transient noise simulations. This module covers the definition of the Power Spectral Density (PSD) function and different methods of building this function. Next, the module covers transient noise analysis-based simulations by varying different parameters. Further, the simulations are covered for comparing the transient noise analysis results with the small-signal AC noise, periodic noise (pnoise), and harmonic balance noise (hbnoise).
  • Jitter analysis: The next module on the jitter analysis briefly introduces jitter and its different metrics. You'll learn about the various functions used for calculating jitter and how to compare the transient noise and periodic noise (pnoise) simulations for jitter measurements using different functions.
  • Using the multiple runs option in transient noise analysis: The final module on using the multiple runs option inside the transient noise analysis form starts with a brief definition of multiple runs. Next, you'll learn about the different functions used while post-processing the results after running the transient noise simulations (having the multiple runs option enabled). Finally, this module covers the simulations for comparing the transient noise analysis results (with the multiple runs option enabled) with the small-signal AC noise results.
How to Enroll
This link gives you more information regarding this course and the link to enroll: Virtuoso Spectre Transient Noise. This course includes slides, audio, and downloadable lab exercises in line with the lecture content.
Want to Learn More?
This training has a Digital Badge that you can earn by passing the exam for this course.
It is also available as "Blended" or "live".
Note: Some training links are accessible only to Cadence customers who have a valid login ID for the Cadence Learning and Support Portal.
  • On the Cadence Support portal, select Register Now and provide the requested information on the Registration page
  • You will need an email address and host ID in order to sign up
  • If you need help with registration, contact support@cadence.com
To stay up-to-date with the latest news and information about Cadence training and webinars, subscribe to the Cadence Training emails.
If you have questions about courses, schedules, online, public, or live onsite training, reach out to us at Cadence Training.
Blogs
Come Join Us and Learn from the Cadence Training Offerings
Do You Want to Flaunt Your Expertise? Grab the Digital Badge Today!
The Year That Was: Knowledge Booster Training Bytes Blog and Video Highlights from 2022
Knowledge Booster Training Bytes – Find and Enroll in a Cadence Online Training Course
Knowledge Booster Training Bytes - The Spectre X Simulator
Online
Courses
Virtuoso Schematic Editor
Virtuoso ADE Explorer and Assembler S1: ADE Explorer and Single Test Corner Analysis
Spectre Simulator Fundamentals S1: Spectre Basics
Spectre Simulator Fundamentals S2: Large-Signal Analyses
Spectre Simulator Fundamentals S3: Small-Signal Analyses
Spectre RF Analysis Using Harmonic Balance
Spectre RF Analysis Using Shooting Newton Method
Product
Manuals
Virtuoso ADE Explorer User Guide
Virtuoso Visualization and Analysis XL User Guide
Spectre Classic Simulator, Spectre APS, Spectre X, Spectre XPS, Spectre FMC Analysis, and Legato Reliability Solution User Guide
Spectre Circuit Simulator and Accelerated Parallel Simulator for RF Analysis in ADE Explorer User Guide
Rapid
Adoption
Kits (RAKs)
Spectre Transient Noise Simulation from ADE – An Introduction
Spectre Transient Noise Simulation from ADE - Advanced
Jee Measurement Using PSS/Pnoise and Transient Noise Analysis
