  3. SKILL for the Skilled: Part 3, Many Ways to Sum a List
Team SKILL
Team SKILL
recursive functions
Team SKILL
Jim Newton
sum a list
recursion
Lisp
SKILL++
18 Sep 2012 • 4 minute read
In Part 1 and Part 2 of this series of posts, I showed a couple of ways to sum up a given list of numbers. In this post, I want to show a couple of ways to use recursive functions to do this.
Recall the sumlist_1a function
In a previous posting the function sumlist_1a was defined.
(defun sumlist_1a (numbers)
  (let ((sum 0))
    (foreach number numbers
      sum = sum + number)
    sum))
Describing this algorithm in words, we see that it does not express the mathematical relationship very well, but it does describe how a Von Neumann machine would perform the calculation.
  • Initialize an accumulator to 0
  • Keep incrementing the accumulator by the successive element of the list
  • When the list is exhausted, return the accumulator
Implementation with simple recursion
The following implementation of sumlist_3a is an example of simple recursion.
(defun sumlist_3a (numbers)
  (if numbers
      (plus (car numbers)
            (sumlist_3a (cdr numbers)))
      0))
Expressing this algorithm in words, you can see that it is more elegant than sumlist_1a as the code actually expresses a mathematical relationship.
  • The sum of the empty list is 0
  • The sum of a N element list is the first element plus the sum of the remaining elements
An advantage of recursive functions such as sumlist_3a is that they are elegant. They often require less code because there is no need to maintain state; e.g., there is no accumulator variable, and no variables are modified during the evaluation of the function.
Implementation with tail recursion
The sumlist_3b function is a tail recursive version of sumlist_3a.
(defun sumlist_3b (numbers)
  (labels ((sum (sum_so_far rest)
             (if rest
                 (sum (plus (car rest) sum_so_far)
                      (cdr rest))
                 sum_so_far)))
    (sum 0 numbers)))
An obvious drawback of this type of recursive function is that it is more difficult for the human to read than simple recursion.
Tail recursion is a technique which can be used to enable recursive function to require no more stack space than iterative functions. There is a pretty clear explanation on Wikipedia.
The main difference, computation-wise, between sumlist_3a and sumlist_3b is the following. In sumlist_3a the final computation the function does is to call the plus function. For example the top level call to sumlist_3a with (1 2 3 4 5 6 7) must completely finish processing (2 3 4 5 6 7) before it can add the 1--the call to (plus 1 ...) cannot occur before the recursive call to sumlist_3a returns.
In sumlist_3b, on the other hand, the computation order is reversed. In the local function, sum, the (plus 1 ...) happens first. That partial sum is passed as the sum_so_far parameter. The final thing the local function does is call itself recursively. There is no pending operating waiting for the recursive call to return.
We'll talk more about why this is important in an upcoming posting of SKILL for the Skilled -- Many Ways to Sum a List.
Testing the functions
If we call sumlist_1a, sumlist_3a, and sumlist_3b on some examples we see that they return the same thing.
(sumlist_1a nil)
=> 0
(sumlist_3a nil)
=> 0
(sumlist_3b nil)
=> 0
(sumlist_1a '(3.4))
=> 3.4
(sumlist_3a '(3.4))
=> 3.4
(sumlist_3b '(3.4))
=> 3.4
(sumlist_1a '(1 2 3 4 5 6 7))
=> 28
(sumlist_3a '(1 2 3 4 5 6 7))
=> 28
(sumlist_3b '(1 2 3 4 5 6 7))
=> 28
Computation order
That the computation order of sumlist_3a and sumlist_3b are opposite can be seen by tracing the plus function.
(trace plus)
==>(plus)
(sumlist_3a '(1 2 3 4 5))
||||||(5 + 0)
||||||plus --> 5
|||||(4 + 5)
|||||plus --> 9
||||(3 + 9)
||||plus --> 12
|||(2 + 12)
|||plus --> 14
||(1 + 14)
||plus --> 15
==>15
(sumlist_3b '(1 2 3 4 5))
||||(1 + 0)
||||plus --> 1
|||||(2 + 1)
|||||plus --> 3
||||||(3 + 3)
||||||plus --> 6
|||||||(4 + 6)
|||||||plus --> 10
||||||||(5 + 10)
||||||||plus --> 15
==>15
Looking at the trace output, we see that sumlist_3a calls plus with first argument being first 5, then 4, 3, 2, and finally 1. However, sumlist_3b, plus is called first with first argument being 1, then with 2, 3, 4, and finally with 5. Since integer addition is commutative, associative, and side effect free, both algorithms give the same result.
This difference in the two computation models might be important in some situations if some function other than plus is used. For example, if a function with side effects is used, you might find that the side-effects happen in a different order.
For example, replacing the 0 with nil, replacing the plus function with cons, and renaming the local function from sum to rev we have two different and useful functions: a list-copy function and a list-reverse function.
(defun copy_3e (numbers)
  (if numbers
      (cons (car numbers)
            (copy_3e (cdr numbers)))
      nil))
(defun reverse_3f (numbers)
  (labels ((rev (list_so_far rest)
             (if rest
                 (rev (cons (car rest) list_so_far)
                      (cdr rest))
                 list_so_far)))
    (rev nil numbers)))
Testing these functions we see the following results:
(copy_3e '(1 2 3 4 5))
==>(1 2 3 4 5)
(reverse_3f '(1 2 3 4 5))
==>(5 4 3 2 1)
Review
In the paragraphs above we looked at two different types of recursive functions. The two techniques usually give compatible results. However, depending on the application one technique may be preferable because of computation order or order of side effects.
More to come
I've alluded several times to the issue that these recursive functions fail for very long lists. In the next post we'll look at some ways of dealing with this issue.
See Also
Tail Recursion
Jim Newton
