  3. Virtuosity: What’s New on the Cadence Learning and Support…
Dishika Majumdar
Dishika Majumdar
RAK series
Custom IC Design flow
CIC flow
RAKs
Virtuoso Layout Suite
Custom IC
Virtuosity: What’s New on the Cadence Learning and Support Portal – Part 1
22 Sep 2020 • 3 minute read
Locked in for past few months, we all are indulging in new activities these days, learning new things, and adding something interesting to our everyday routine. Along similar lines, we are happy to share with you the Custom IC Design Flow/Methodology RAK series on the Cadence Learning and Support portal.
The Custom IC Design Flow/Methodology RAK series walks you through a sample design flow, illustrating the use of the Custom IC Virtuoso Platform tools at various design stages.
The RAK series covers the entire front-to-back Custom IC Design flow, where each stage is based on the Concurrent Design Methodology. The series uses the same design throughout and each RAK is independent in itself as well.
Insights
The RAKs in this series demonstrate how Cadence Custom IC tools map in the Analog or Mixed Signal design methodology to meet the needs of designers. The labs are based on a realistic design, which blend the design methodology concepts with the tool tasks. They demonstrate an illustrative flow.
Note: These RAKs are not intended to teach individual tools.
How to Access This Series
To access the series either click here, or do one of the following on the Cadence Learning and Support portal:
  • Search for cic flow, and then select the Custom IC Design Flow/Methodology (Advanced) link listed in the Featured Results.
  • Click Tools > Custom IC Design, and then select the Custom IC Design Flow/Methodology (Advanced) link.
For future references, add this page to your favorites. Click the 3-dots icon on the top-right corner of the page and then click the Add to Favorites icon.
Rapid Adoption Kits
  • Custom IC Design Flow/Methodology
  • Custom IC Design Flow/Methodology: Schematic Capture & Circuit Simulation
  • Custom IC Design Flow/Methodology: Circuit Layout
  • Custom IC Design Flow/Methodology: Circuit Physical Verification and Parasitic Extraction
  • Custom IC Design Flow/Methodology: Post Layout Circuit Simulation
  • Custom IC Design Flow/Methodology: GDSII Generation
  • Basics of Analog Flow: A Design Oriented Approach
Happy reading, and stay safe!
Sanjay Gupta and Dishika Majumdar
About Virtuosity
Virtuosity has been our most viewed and admired blog series for a long time. The series has brought to the fore some less well-known yet very useful software and documentation improvements and has also shed light on some exciting new offerings in Virtuoso. This series broadcasts the voices of different bloggers and experts, who continue to preserve the legacy of Virtuosity and try to give new dimensions to it by covering topics across the length and breadth of Virtuoso, and a lot more. To receive notifications about the new blogs in this series, click Subscribe and submit your email ID in the Subscriptions box.
