  3. Virtuosity: Smart View Multi-Process Corners in Virtuoso…
Arja H
Arja H
Extraction
Smart View
ICADVM18.1
ADE Explorer
multi-process corners
Virtuosity
qrc
Custom IC
IC6.1.8
ADE Assembler
Virtuosity: Smart View Multi-Process Corners in Virtuoso ADE Assembler and Explorer
17 Sep 2020 • 3 minute read
The Cadence® Quantus Smart View is the next generation of the Extracted View in the Virtuoso environment and has been available since the release of IC6.18/ICADVM18.1. You may recall my blog about Smart View - Virtuosity: a Smart Extracted View, that introduced this new view.
The Smart View provides the same functionality as the Extracted View, but it uses a highly efficient and scalable storage mechanism. This means that Smart Views can manage larger, more complex designs at advanced nodes with a reduced overall extraction run time and netlist size. In fact, the Smart View not only helps with faster netlist generation in Virtuoso® ADE Assembler and Virtuoso® ADE Explorer, but you can also use it to to analyze values and connectivity details of extracted parasitic elements.
Starting from the IC6.1.8/ICADVM18.1 ISR13 releases, multi-process corners - (MPCs),  are supported in Smart Views too. This means that the design can be extracted over several technology corners and these corners are all contained within one Smart View.
You can then simulate across these MPCs from within Virtuoso ADE Assembler and Virtuoso ADE Explorer. This is all explained in the updated Using Quantus Smart View in the Virtuoso Analog Design Environment Rapid Adoption Kit (RAK). To download the RAK, click here or search for it on the Cadence Support portal. The RAK details how to:
  • Create a Smart View
  • Set up ADE to use Smart Views
  • Perform in and out-of-context probing
  • Display parasitics in layout
  • Create parasitic reports
  • Use multi-process corners within a Smart View
You can also check out the Using Smart View in the ADE Flow video to see a demo of these features.
  • Rapid Adoption Kit
    • Using Quantus Smart View in the Virtuoso Analog Design Environment RAK
  • Video
    • Using Smart View in the ADE Flow
  • Blog
    • Virtuosity: a Smart Extracted View
  • User Guides
    • Quantus QRC Extraction User Manual
    • Virtuoso Layout Suite XL User Guide
    • Virtuoso Parasitic Aware Design User Guide
Happy Reading!
Arja
About Virtuosity
Virtuosity has been our most viewed and admired blog series for a long time. The series has brought to the fore some less well-known yet very useful software and documentation improvements and has also shed light on some exciting new offerings in Virtuoso. This series broadcasts the voices of different bloggers and experts, who continue to preserve the legacy of Virtuosity and try to give new dimensions to it by covering topics across the length and breadth of Virtuoso, and a lot more. To receive notifications about the new blogs in this series, click Subscribe  and submit your email ID in the Subscriptions box.
