  3. Virtuoso ICADVM20.1 ISR24 and IC6.1.8 ISR24 Now Availab…
Virtuoso Release Team
Analog Design Environment
Cadence blogs
Virtuoso RF Solution
IC Release Announcement blog
Virtuoso RF
Layout EXL
ICADVM20.1
IC Release Blog
Virtuoso ADE Explorer
Virtuoso Layout Suite
Custom IC
Virtuoso ADE Assembler
IC6.1.8
Virtuoso ICADVM20.1 ISR24 and IC6.1.8 ISR24 Now Available
30 Mar 2022 • 2 minute read
The ICADVM20.1 ISR24 and IC6.1.8 ISR24 production releases are now available for download at Cadence Downloads. For information on supported platforms and other release compatibility information, see the README.txt file in the installation hierarchy.
  • ICADVM20.1 ISR24
  • IC6.1.8 ISR24
Here's a list of the most important updates made in the current releases:
ICADVM20.1 ISR24 Only
  • New Pin Ordering Option in Die Export (Virtuoso RF Solution)
    A new mode, Use predefined ordering, has been added to define pin numbering on an exported die. It lets you define pin numbering based on predefined or custom algorithms.
  • Check Router Violations and Run Router in Pin Accessibility Checker (Virtuoso Layout Suite EXL)
    Use the Run Router field in the Pin Accessibility Checker to run the Cadence® InnovusTM router in the background without checking out an Innovus license. In addition, use the Check Violations in Router option to view the routed topology view in Cadence Innovus router.
ICADVM20.1 and IC6.1.8 ISR24
  • Measure Outputs Across Any Dimension (Virtuoso ADE Explorer, Virtuoso ADE Assembler)
    Use the new eval type any to create outputs that can be measured across any dimension. For these outputs, the tool adds the measureAcross function that you can edit to specify the desired expression and the dimensions across which you want to evaluate that expression.
  • Revamped Graph Properties Form for Circular Graphs (Virtuoso Visualization and Analysis XL)
    Use the revamped Graph Properties form for circular graphs to specify various graphs and grid properties. You can also use this form to annotate VSWR (Voltage Standing Wave Ratio) circles and Q contours on the Smith grids.
  • What’s New in Virtuoso IC6.1.8 ISR24 and ICADVM20.1 ISR24 (Application Notes)
  • ICADVM20.1 What's New
  • IC6.1.8 What's New
