  3. Virtuoso ICADVM20.1 ISR32 and IC6.1.8 ISR32 Now Availab…
Virtuoso Release Team
Cadence blogs
ADE Explorer
Virtuoso RF Solution
IC Release Announcement blog
ViVA
ICADVM20.1
IC Release Blog
IC6.1.8
Cadence Community
ADE Assembler
Virtuoso ICADVM20.1 ISR32 and IC6.1.8 ISR32 Now Available
16 May 2023 • 2 minute read
A wooden block on a keyboard with a download icon
The ICADVM20.1 ISR32 and IC6.1.8 ISR32 production releases are now available for download at Cadence Downloads. For information on supported platforms and other release compatibility information, see the README.txt file in the installation hierarchy.
  • ICADVM20.1 ISR32
  • IC6.1.8 ISR32
Here's a list of the highlights from our recent ICADVM20.1 and IC6.1.8 releases:
  • Schematic Pin Generation in the Full Cellview Flow (Virtuoso RF Solution)
    The schematic pins are created only for the layout pins that have a port. If the common node net exists and is not set to gnd!, a pin is created.
  • Selection of Die Bumps or BGA Balls in the Palette Assistant (Virtuoso RF Solution)
    Use Pins in the Objects panel of the Palette assistant to select die bumps and BGA balls.
  • Assisted Synchronization of Virtuoso and SiP Layouts (Virtuoso RF Solution)
    Use the newly-introduced assisted flows to update changes made to a Virtuoso RF Solution compatible layout to the corresponding SiP file and vice versa.
  • Support for Fillet Creation (Virtuoso RF Solution)
    Use the Fillet tab of the Metal Density Options form to create and control fillet insertion in the design. Fillets are an extra etch added to prevent acid traps on a design, which in turn improves yield and manufacturability.
  • Using the DSPF-in-the-Middle Flow for AMS Simulations (Virtuoso ADE Explorer, Virtuoso ADE Assembler)
    Use the check box Using HED Config for DSPF Blackbox in the Simulation Files Setup form for AMS simulator to enable the DSPF-in-the-middle flow for ADE Explorer or ADE Assembler.
  • Sweep DSPF Files Using the VAR Function (Virtuoso ADE Explorer, Virtuoso ADE Assembler)
    Use the VAR function to sweep DSPF files specified in the Simulation Files Setup form or in the Corners Setup form.
  • What’s New in Virtuoso IC6.1.8 ISR32 and ICADVM20.1 ISR32 (Application Notes)
  • ICADVM20.1 What's New
  • IC6.1.8 What's New
To receive Virtuoso release announcements like this one, and other Virtuoso-related information, directly in your mailbox, select the SUBSCRIBE check box in the Subscriptions box.
