  3. Virtuoso ICADVM20.1 ISR26 and IC6.1.8 ISR26 Now Availab…
Virtuoso Release Team
Analog Design Environment
Cadence blogs
ICADVM18.1
ADE Explorer
cadence
Virtuoso RF Solution
IC Release Announcement blog
Layout EXL
IC Release Blog
Custom IC
IC6.1.8
ADE Assembler
Virtuoso Layout Suite XL
Virtuoso ICADVM20.1 ISR26 and IC6.1.8 ISR26 Now Available
8 Jul 2022 • 2 minute read
The ICADVM20.1 ISR26 and IC6.1.8 ISR26 production releases are now available for download at Cadence Downloads. For information on supported platforms and other release compatibility information, see the README.txt file in the installation hierarchy.
  • ICADVM20.1 ISR26
  • IC6.1.8 ISR26
Here's a list of the most important updates made in the current releases:
ICADVM20.1 ISR26 Only
  • Selection of Die Bumps or BGA Balls in the Palette Assistant (Virtuoso RF Solution)
    Use Pins in the Objects panel of the Palette assistant to select die bumps and BGA balls.
ICADVM20.1 and IC6.1.8 ISR26
  • Using the DSPF-in-the-Middle Flow for AMS Simulations (Virtuoso ADE Explorer, Virtuoso ADE Assembler)
    Use the check box Using HED Config for DSPF Blackbox in the Simulation Files Setup form for AMS simulator to enable the DSPF-in-the-middle flow for ADE Explorer or ADE Assembler.
You can also check out the following highlight from the ICADVM20.1 and IC6.1.8 ISR25 releases:
  • Assisted Synchronization of Virtuoso and SiP Layouts (Virtuoso RF Solution)
    Use the assisted flows to update changes made to a Virtuoso RF Solution compatible layout to the corresponding SiP file and vice versa.
  • Support for Fillet Creation (Virtuoso RF Solution)
    Use the Fillet tab of the Metal Density Options form to create and control fillet insertion in the design. Fillets are an extra etch added to prevent acid traps on a design, which in turn improves yield and manufacturability.
  • Sweep DSPF Files Using the VAR Function (Virtuoso ADE Explorer, Virtuoso ADE Assembler)
    Use the VAR function to sweep DSPF files specified in the Simulation Files Setup form or in the Corners Setup form.
  • What’s New in Virtuoso IC6.1.8 ISR26 and ICADVM20.1 ISR26 (Application Notes)
  • ICADVM20.1 What's New
  • IC6.1.8 What's New
