  3. Virtuoso Studio IC25.1 ISR9 Now Available
KomalJohar
KomalJohar
IC25.1
featured
Cadence blogs
Virtuoso Studio
IC Release Announcement blog
IC Release Blog
10 Nov 2026 • 4 minute read
Virtuoso Studio
The Virtuoso Studio IC25.1 ISR release is now available at Cadence Downloads. The README.txt file in the installation directory provides information about supported platforms and other release compatibility.
IC25.1
Here's a list of the highlights from the Virtuoso Studio IC25.1 ISR release:
  • Loading Previously Used Multiphysics Storage for Referenced Models (Virtuoso Heterogenous Integration)
    Load the previously used storage type, such as local storage or a multiphysics view, for selected referenced models in a design to eliminate the need to manually locate and load the storage. Use the Load Multiphysics Views in Referenced Models button on the multiphysics analysis assistant toolbar to load a previously used storage. The storage status for the referenced designs is displayed in CIW.
  • Generating Design Area Summary (Virtuoso ADE Artist, Virtuoso ADE Assembler)
    Evaluate device area results using the area goal summary form, which consolidates area results for devices to compare areas across corners and filter by corner name. Use this form to improve design analysis efficiency and accelerate area-driven optimization decisions.
  • Customizing Area Goal Calculation (Virtuoso ADE Artist, Virtuoso ADE Assembler)
    Use the includeInstances and excludeInstances arguments in the getCellArea SKILL function to include or exclude specific instances for the calculation of the area of a design.
  • Modernized Datasheet Experience with Flexible Customization (Virtuoso ADE Artist, Virtuoso ADE Assembler, Virtuoso ADE Explorer)
    The datasheets have been enhanced for an interactive viewing experience. They offer a more intuitive and streamlined way to review simulation results. The tabbed view makes it easier to navigate across different sections and analyze results efficiently. The filtering and sorting capabilities help you quickly locate and analyze specific data and provide column visibility control so you can customize the displayed information.
  • Measuring TDECQ Using the Eye Diagram Assistant (Virtuoso Visualization and Analysis XL)
    Use the TDECQ tab in the eye diagram assistant to measure Transmitter and Dispersion Eye Closure Quaternary (TDECQ) and other important metrics for a PAM4 optical signal.
  • Automatic Checking and Updating of IC Component Thickness Values (Virtuoso Heterogenous Integration)
    To avoid manually specifying the thickness of IC instances and to ensure consistency between IC layout instances and their referenced IC models, the Settings tab in the multiphysics analysis toolbar provides automated support for checking and updating thickness values. The Check IC Thickness and Update IC Thickness options automatically detect thickness mismatches between IC instances and their referenced models and synchronize thickness values across package design.
  • Retaining Design Hierarchy of a Plotted Signal (Virtuoso ADE Artist, Virtuoso ADE Assembler)
    The design hierarchy of plotted signals is now retained even after resubmitting the simulation.
  • Saving and Restarting Unfinished Error Points (Virtuoso ADE Artist, Virtuoso ADE Assembler)
    The save and restart flow saves the state files generated during the simulation run for transient analysis. This enables you to directly run the simulation for a specific history item using the Rerun Unfinished/Error Points option from the context menu of the History tab. The Enable save/restart flow for transient analysis option in the run options form enables the feature by default.
  • Adding Reliability Degradation Parameters (Virtuoso ADE Artist, Virtuoso ADE Assembler, Virtuoso ADE Explorer)
    Use relexpr expressions to add the reliability degradation parameters that can help retrieve information about the maximum, minimum, or the number of parameters violating the reliability threshold. The relexpr expressions can be specified in the Outputs Setup pane.
  • Optimizing Duplicate Simulation Runs in Reliability Scenarios (Virtuoso ADE Artist, Virtuoso ADE Assembler, Virtuoso ADE Explorer)
    Simulation runs in reliability scenarios are now optimized by identifying the results of unique corners and reusing them across design points. This enables you to avoid duplicate runs because the results of a scenario can be reused in other scenarios when running fresh or stress-stage simulations in the aging scenario.
  • What's New in Virtuoso Studio IC25.1 ISR9 (Application Notes)
  • Virtuoso Studio IC25.1 New
To receive Virtuoso AI Studio release announcements like this one and other Virtuoso AI Studio-related information directly in your mailbox, click SUBSCRIBE on the analog/custom design blog page.
Virtuoso Release Team
