  3. Virtuoso Video Diary: Introducing the New Search Functionality…
kmayank
kmayank
Search
HED
hierarchy editor
Virtuoso Video Diary: Introducing the New Search Functionality in Hierarchy Editor
14 Dec 2016 • 2 minute read
Are you still crawling through the set of tabs, panes, or tables in the Hierarchy Editor (HED) to find the information you are looking for? That must be frustrating, isn’t it? You could try the new Search functionality in HED that will help you get access to the required information rather quickly.
In a dynamic environment, a search functionality makes your application more interactive and improves your productivity. All you need to do is enter a search keyword and/or phrase to get the desired results.
Search Functionality in HED
The Search functionality in HED helps you search for a cell name, instance name, or occurrence path in the Virtuoso® Hierarchy Editor window, and the results are highlighted immediately in the Table view and Tree view. You can either use the Search text box in the HED toolbar or the Search Assistant Pane to enter your search string.
HED Toolbar
The search functionality on the HED toolbar consists of the following UI components:
  • The Search Text Box: Allows you to specify search keywords or phrases.
  • Show Results Drop-down List: Displays a recent search history list using which you can immediately retrieve the results of any recent searches.
  • Advanced Search: Provides the commonly used search options to refine your search results.
The interactive Search assistant pane is a dockable/undockable pane that displays additional information as compared to the HED toolbar.
For more information on the search functionality in HED, you can view the Using the Search Functionality in Hierarchy Editor video on Cadence Online Support. Click the video link now or visit Cadence Online Support and search under Resources — Video Library.
Note: If you don’t have a Cadence Online Support account, you can play the Using the Search Functionality in Hierarchy Editor video (mp4) natively in Cadence Help when you are using Virtuoso IC6.1.7/ ICADV12.2 (ISR4 or later). In the Cadence Help Virtuoso Documentation Library, look under Video Demos.
Virtuoso Hierarchy Editor User Guide
  • Using the Search Functionality
Note: For more information on Cadence products and services, visit www.cadence.com.
About Virtuoso Video Diary
Virtuoso Video Diary is an online journal that relays information about Virtuoso videos that are available in the Cadence Online Support Video Library. For IC6.1.7 and ICADV12.2, over 100 videos on a wide variety of new and exciting Virtuoso features have already been created. Virtuoso Video Diary brings you direct links to these videos and other related material, on regular basis, in your mailbox. Subscribe to receive the e-mail notifications.
Mayank Kumar
