  3. 2.5D + 3D = “3.5D”!
Reela Samuel
Reela Samuel
Allegro X AI
Integrity 3D-IC Platform
3D-IC
advanced packaging
AI-Driven Design
AI for design
3.5D
AI/ML
AI
2.5D
semiconductors
2.5D + 3D = “3.5D”!
5 May 2026 • 5 minute read
3.5D with cadence APD
Architecting the Next Generation of AI Silicon
The semiconductor industry is no longer defined solely by transistor scaling. As Moore's law decelerates, advanced packaging has become the primary lever for achieving system-level performance gains. Within this landscape, the equation 2.5D + 3D = 3.5D—defying the instincts of basic math and physics—captures a pivotal architectural evolution: one that balances performance, manufacturability, cost, and thermal efficiency in ways neither traditional planar designs nor purely vertical stacks can.
At its core, "3.5D" integration represents a new class of heterogeneous system architecture that directly addresses the technological and economic pressures driving AI and high-performance computing (HPC) silicon today.
From Planar Modularity to Vertical Bandwidth
Initially, the industry transitioned from conventional 2D monolithic systems and multi-chip module (MCM) designs to 2.5D integration to meet growing system bandwidth demands. In this model, multiple dies, logic, high-bandwidth memory (HBM), and various accelerators are placed side by side on an advanced package, which includes a high-density silicon interposer. The interposer, acting as a high-speed interconnect plane, provides significantly denser die-to-die connections than organic substrates and enables heterogeneous integration across process nodes. This approach has matured over the past decade and has become the backbone of many leading AI accelerators and HPC processors.
2.5D IntegrationHowever, as performance expectations have multiplied, the industry has encountered the inherent limits of lateral disaggregation and integration. While 2.5D interposers deliver impressive bandwidth and modular scalability, reticle limits and yield degradation at large die sizes continue to constrain monolithic scaling. Also, communication between disaggregated chips or chiplets still relies on micro-bumps and routed wiring, which are fundamentally constrained in density and latency compared to what vertical integration can achieve.
The Promise—and Constraints—of 3D Stacking
Driven by the need for even tighter integration, 3D integration has emerged as a compelling alternative. By stacking dies via copper-to-copper hybrid bonding and through-silicon vias (TSVs), designers can achieve dramatically shorter interconnect distances, significantly higher signal density, lower power per bit, and reduced latency. This vertical dimension unlocks performance that planar integration alone cannot match.
3D-IC Vertical StackingYet, as documented in industry analyses, full 3D stacking introduces serious practical challenges when applied to high-power logic devices. Vertically stacked logic, particularly at AI performance levels, generates difficult-to-remove heat, and the yield risk inherent in a multi-die stack can compound manufacturing costs. Every additional layer adds not only complexity but also potential points of failure, impacting both yield and reliability.
In short, while fully stacked 3D logic delivers exceptional performance potential, its operational barriers have slowed widespread commercialization.
3.5D: A Strategic Architectural Synthesis
Faced with these trade-offs, the industry is converging on a hybrid architectural approach, labeled "3.5D integration". This architecture is best understood not as a compromise in performance, but as a refined system design philosophy that leverages the strengths of both 2.5D and 3D.
In 3.5D, select dies—especially those that require the highest bandwidth and lowest latency—are bonded vertically using hybrid copper-to-copper intrconnects. These bonded stacks are then placed on a silicon interposer alongside other critical components such as memory and I/O. By localizing vertical integration to the most communication-intensive elements, 3.5D achieves interconnect density and power efficiency that approach those of full 3D stacking, while preserving the manufacturing advantage of a 2.5D substrate.
Hybrid bonding drives a step-change in interconnect performance, enabling signal densities on the order of 7X those of micro-bumps and reducing interface power by roughly 10X compared to traditional flip-chip connections. These gains are essential for next-generation AI XPUs where die-to-die bandwidth dominates overall system throughput.
Reframing Performance for AI and HPC Workloads
Modern AI systems are not single chips; they are complex systems in a package. These systems combine multiple compute tiles, stacked memory, and high-speed I/Os in designs where every interconnect matters. The ability to partition functions intelligently—placing tightly coupled compute blocks in vertical proximity while preserving planar distribution for memory and I/Os, enables architects to optimize performance without crosscutting the thermal and reliability stresses that plague full 3D stacks.
From a strategic perspective, "3.5D" addresses a core industry tension: how to maximize performance density without disproportionately escalating costs and risk. Smaller individual dies improve manufacturing yield. Applying hybrid bonding only to high-value interconnect paths limits the use of expensive processes to where they matter most. Heterogeneous elements that do not benefit as significantly from vertical proximity remain laterally integrated, and aiding heat dissipation.
This balanced approach reflects the industry's recognition that system-level architecture, not silicon scaling alone, determines real-world performance gains.
Design and Ecosystem Implications
Implementing "3.5D" is not merely a packaging task; it is a system-wide engineering discipline. Designers must consider co-optimization across electrical, thermal, and mechanical domains. Package warpage, power integrity, timing closure, and thermal management all interact in more complex ways than in purely planar configurations. As chip power levels approach kilowatt-scale within a package, these interactions can no longer be treated as secondary concerns. Instead, they must be a core part of the design process from concept through verification.
In practice, "3.5D" design requires design-centric and package-centric considerations to be addressed together from the start. Architectural decisions around die partitioning, bandwidth, power, and timing are tightly coupled with package-level thermal, mechanical, and manufacturing constraints. Tool-enabled co-optimization across these domains allows teams to evaluate and refine system tradeoffs early and continuously throughout the design flow.
Advanced simulation tools, multiphysics modeling, and digital twin methodologies are rapidly becoming essential across the ecosystem to ensure first-pass architectural success.
Industry Momentum and Competitive Positioning
The rapid adoption of "3.5D" in the industry reflects its alignment with commercial realities. Leading vendors are investing in this technology to enable future AI accelerators that exceed the capabilities achievable through 2.5D alone, without the prohibitive risks of full 3D integration.
For example, platforms such as this 3.5D system illustrate how this architecture can scale multi-tile systems with improved signal density and efficiency, while still maintaining manageable manufacturing profiles and thermal behavior.
"3.5D" also responds to broader market trends. As chiplet-centric design becomes the norm, accounting for a significant and growing share of advanced packaging solutions, the ability to scale heterogeneous systems efficiently is now a strategic differentiator.
The Architecture of Practical Innovation
The transition from 2.5D to "3.5D" integration represents more than incremental improvement. It signals a shift in how semiconductors are architected in the AI era: not by shrinking transistors, but by intelligently organizing functional units in three dimensions to optimize performance, cost, power, and reliability simultaneously.
  • 2.5D brought modular scalability
  • 3D demonstrated the limits of vertical density
  • "3.5D" delivers a durable path forward—one that is both technologically ambitious and economically viable
In an industry where every nanosecond of latency and millimeter of package real estate counts, "3.5D" is emerging as the architecture that makes future AI silicon both possible and practical.
Explore how a unified design-centric and package-centric approach can accelerate your 3.5D architecture journey—learn more about Cadence Integrity 3D-IC Platform and Cadence Allegro Package Designer Plus.
