  3. Accelerate Your Design Signoff with Cadence Voltus Training…
Vinod Khera
Vinod Khera
si/pi
fault coverage
voltus training kit
signoff
Accelerate Your Design Signoff with Cadence Voltus Training Kit
17 Dec 2025 • 6 minute read
By Ronen Stilkol, Senior AE Architect
In the rapidly evolving world of semiconductor design, signoff challenges are growing due to increasing complexity, shrinking technology, a rising number of transistors, and the adoption of 3D-IC technology. Additionally, there are escalating electromigration (EM) violations during signoff, making power integrity (PI) a critical issue at advanced nodes. Engineers require robust tools and methodologies to address these challenges effectively to expedite the design signoff process.
The Cadence support team has transformed and accelerated the signoff process with the comprehensive Voltus Training Kit. The Voltus training kit includes direct read links for IR basics, Data input preparation, Design input, and Libraries checks, RLRP simulation, Static Simulation, Dynamic Simulation, Power-up Simulation, Die model, Thermal simulations, Signal EM, ESD, Hierarchy Simulation, IR Aware Timing, 3DIC, Package SPA, SoC with Analog Design, Insight and Table2IR to expedite the design as user need not to open the tar gzipped file". This innovative resource simplifies complex power analysis methodologies into hands-on learning experiences. This blog post explores how the Voltus Training Kit assists engineers in accelerating the design signoff process.
Voltus Training Kit – A Few Insights
The Voltus Training Kit is a methodology-driven, easy-to-use training kit designed to accelerate design signoff. More than just a point tool, it’s a complete methodology-based solution for chip design and production signoff. It requires no prior knowledge—users untar the kit, set the environment, and use make commands to run simulations. The kit includes advanced simulation capabilities and integration with the broader Cadence ecosystem:
Advanced Simulation Capabilities
The Voltus Training Kit offers advanced simulation capabilities that are beyond basic simulation
  • Thermal analysis: Third-party system-level simulations using the Celsius Thermal Solver
  • ESD protection: Comprehensive electrostatic discharge analysis
  • 3D-IC design: Multi-die integration and analysis techniques
  • Package SPA: Signal and power integrity analysis using Sigrity X technologies
  • Analog integration: SoC with analog design using Virtuoso Studio and Voltus-Fi Custom Power Integrity Solution
  • IR-aware timing: Advanced timing analysis with Tempus Timing Signoff Solution
Tool Integration
The Voltus Training Kit's design integration feature allows designers to apply learned concepts directly to their current projects. With its structured hands-on learning approach, the Voltus Training Kit enables individuals—from novices to experts—to quickly learn industry best practices. It uses various Cadence tools to accelerate the design signoff:
  • Insight: Advanced power grid analysis and optimization with Innovus Implementation System
  • Synthesis: Design synthesis with Genus Synthesis Solution
  • Place and route: Implementation with the Innovus Implementation System
  • Extraction: SPEF extraction with Quantus Extraction Solution
  • Library creation: CCSP and other library generation with Liberate Trio Characterization Suite
  • The recent VTK update introduces several new features. Pegasus has been added, along with the capability to run Pegasus PG metal fill after Insight.
  • Users can now check Pegasus's contribution to IR drop and create test cases using the 'write_testcase' command. Additionally, the update facilitates running test case data after correcting the command file input data path. It also includes simulations of STATIC hierarchy and multi-state dynamic hierarchy, as well as the conversion of AVM to datasheet PGV. Lastly, an auto-complete feature has been implemented to simplify command entry.
What Makes the Voltus Training Kit Your Ultimate Companion?
The Voltus Training Kit stands out as the ultimate companion in chip design. It provides major foundry-guided scripts for signoff processes, eliminating the need to go through exhaustive documents. Additionally, the kit includes a checklist and simulation guides to ensure thorough design reviews. Whether running flat or hierarchical simulations, the Voltus Training Kit ensures accuracy and confidence in the results. Built around Cadence's industry-leading Voltus platform and integrated into a full CAD environment, the kit offers everything to address design signoff challenges. Its comprehensive range of features caters to startups and established enterprises, ensuring efficiency and reliability while helping to accelerate the signoff process.
  • 160+ Rapid Adoption Kits (RAKs): Extensive collection of real-world simulation scenarios, running Voltus and other Cadence tools, with ready-to-run design and simulation examples
  • Zero prerequisites: Start learning immediately, regardless of your current experience level
  • Industry-standard methodology: Built on recommended Cadence PV scripts and third-party PVT tables.
  • Multi-mode support: Compatible with both DP/XP and Common_UI/Legacy modes
  • Comprehensive coverage: Covers basic simulations to advanced topics like 3D-IC and thermal analysis
  • Speed and ease: Offers hassle-free installation and avoids the need for script rebuilding, plus lightning-fast run times, shortened evaluation, and ramp-up times enable the onboarding from months to days
  • Expanded functionality: Combines the die and package design for comprehensive solutions in analog, digital, and mixed design spaces
The Voltus Training Kit boosts confidence in design outputs and facilitates rapid skill development through its organized, practical learning methods.
A Systematic Approach to Signoff Methodology
The Voltus Training Kit follows a proven signoff methodology that ensures the early detection of design weaknesses and comprehensive failure coverage. The structured approach guides you through seven critical stages:
  1. Design foundation checks identify and resolve fundamental issues such as missing vias, shorts, and unconnected devices, wires, and the library inputs before they become costly problems
  2. Power grid quality assessment, by evaluating the PDN hookup quality of an instance
  3. Static simulation to verify that the power grid's metal density can adequately supply the design average current requirements
  4. Dynamic vectorless analysis to utilize intelligent cell selection techniques for high-coverage detection of design weaknesses
  5. SCAN-based testing to evaluate the maximum peak demand current of designs
  6. Dynamic RTL VCD integration helps work with real activity values and state propagation for accurate power analysis
  7. Dynamic gate-level true timing helps to work with the most sophisticated gate-level VCD with true timing simulation, which can be used for silicon correlation
Getting Started: Simplified Setup Process
One of the Voltus Training Kit's greatest strengths is its user-friendly setup process. Within minutes, you can have a complete learning environment running:
# Download from the ASK Cadence portal
         cd your_work_area
         gtar -zxvf VTK_DEC_31_2025.tar.gz
         cd VTK_DEC_31_2025/Voltus_Training_Kit
# Configure your environment
          source environment_settings
          make <simulation_name>
The intuitive make-based command structure provides easy access to all functionalities:
         make CLEAN - Reset your environment
         make <simulation>_READ - Launch GUI for results analysis
         make INSIGHT_HELP - Access specialized Innovus Insight workflows
         make DOC_READ - Browse comprehensive documentation
Bring Your Design: Real-World Application
The Voltus Training Kit is highly effective in applying learned concepts to real projects. The kit provides seamless integration pathways for custom designs. The evaluation and ramp-up process using the kit involves the following steps.
  • Download Voltus Training kit
  • Run: make REQUIRED_VOLTUS_DESIGN or make REQUIRED_INSIGHT_DESIGN to prepare the design inputs
  • Run: make ADD_VOLTUS_DESIGN or make ADD_INSIGHT_DESIGN to add the design to VTK
  • Update the block setup file manually <new_block>/simulation/General/setup.tcl if needed
  • Source the environment_settings file
  • Run make commands to simulate the design
  • The design review presentation is included
Success with the Voltus Training Kit
In an industry where power efficiency and signal integrity can determine a product's success, the Voltus Training Kit offers a competitive advantage. Whether adopting new technologies, developing test cases for quality assurance, or exploring proof-of-concept implementations, the Voltus Training Kit provides a comprehensive training experience that transforms theoretical knowledge into practical skills. As power integrity challenges become more complex, design cycles are shortening, and the margin for error continues to decrease. The Voltus Training Kit helps designers stay ahead of these challenges.
Ready to transform your power integrity expertise? Download the Voltus Training Kit from the Cadence ASK portal today and discover why leading engineers worldwide trust Cadence tools for their most critical design challenges.
For more information, visit the Cadence ASK portal or contact the support team for personalized guidance on maximizing your Voltus Training Kit experience.
