  3. Cadence Welcomes Ausdia and TimeVision Timing Constraints…
digital design
Digital Design and Signoff
featured
Tempus timing solution
Timing analysis
signoff
Tempus Timing Signoff Solution
Cadence TimeVision Solution
Cadence Welcomes Ausdia and TimeVision Timing Constraints Management Solution
2 Jun 2026 • 2 minute read
We're delighted to welcome Ausdia to Cadence. Effective April 16, 2026, Ausdia's flagship TimeVision timing constraints management solution is now part of the Cadence portfolio, strengthening our mission to deliver the most complete and scalable timing signoff solution available on the market.
Why Timing Constraints Are the New Frontier of Signoff Risk
As designs push deeper into advanced process nodes, timing closure has never been more demanding. But increasingly, the root cause of signoff failures isn't the signoff tools themselves—it's the constraints that feed them.
Missing, incorrect, or inconsistent timing constraints can silently propagate through the design flow, only surfacing late in the process when the cost of fixing them is highest. For complex SoCs with millions of timing paths, manually catching these issues is no longer realistic.
The industry needs a smarter approach—and that's exactly what Cadence TimeVision Solution is designed to deliver.
Introducing Cadence TimeVision Solution: Automated Constraint Development and Management
The TimeVision Solution is an industry-proven platform that automatically identifies constraint errors across the entire design flow, from RTL to signoff. By combining structural analysis, timing analysis, and formal verification techniques, the TimeVision Solution brings a level of rigor and automation to constraint management that was previously out of reach for most teams.
The platform is built for scale—designed to handle the complexity of the largest, most advanced SoC designs in production today. It doesn't just find problems; it helps teams develop better constraints from the start, reducing iteration cycles and accelerating time to silicon.
The TimeVision Solution is already trusted by some of the world's leading semiconductor companies with plan-of-record deployments that demonstrate its real-world impact at scale.
What This Means for Cadence Customers
While the TimeVision Solution will continue to be supported by Cadence as a standalone tool, it will also be integrated into the Tempus Timing Solution portfolio, offering a truly end-to-end timing signoff solution that spans constraint development and management all the way through final static timing analysis (STA) signoff.
For our customers, this means:
  • Fewer late-stage surprises: Catch constraint issues early, before they become costly silicon failures.
  • Faster closure: Automated constraint management reduces manual debug time and accelerates signoff.
  • Greater confidence: Know that your constraints are correct before you ever run the final STA.
The Road Ahead
The addition of the TimeVision Solution to the Cadence portfolio reflects our continued commitment to leading the constraint verification market segment—and to continuously raising the bar for what's possible in digital design signoff.
Ready to learn more? Reach out to your Cadence account team or use our contact form to explore how the Cadence TimeVision Solution and the Tempus Timing Solution can transform your timing signoff process.
