  3. Do You Want to Explore Instances in Genus Synthesis Solution…
Neha Joshi
Neha Joshi
Genus
gui
place and route
highlighted objects
physical implementation
Do You Want to Explore Instances in Genus Synthesis Solution Layout GUI?
6 May 2022 • Less than one minute read
What comes to your mind when we say Genus Layout GUI (Graphical User Interface)? You picture the floorplan filled with instances and objects. Imagine you need to highlight the specific instance or timing path in GUI?
Do you think it’s tricky? Not at all!!
Genus Synthesis Solution GUI (Graphical User Interface) helps you view and highlight the instances and timing results to better explore/debug your design.
Now think about your favorite color; wanna highlight the instance(s) in GUI with that? Think about all the objects in the timing path; wanna see them in GUI?
How? It’s easy.
To explore highlighting the instances in Genus Layout GUI and analyze the timing report, refer to the latest videos on https://support.cadence.com [Cadence login required].
Video Titles:
How to Highlight Instances Using the Command gui_highlight_pv in Genus Synthesis Solution? (Video)
How to View Timing Report Path in Genus Synthesis Solution GUI?(Video)
Related Resources:
Enhance the Genus Synthesis experience with videos: Genus Synthesis Solution: Video Library
