  3. Encounter Puzzler #3: Renaming a Net Logically
BobD
BobD
dbGet
puzzler
tcl
28 Feb 2011 • 1 minute read
The other day a designer E-mailed me: How can we rename a net in Encounter?
I followed up to clarify whether the designer wanted to change the net associated with routed wire segments, or wanted to rename a signal net. He clarified that he wanted to change a logical signal net's name.
Changing the net name associated with a routed wire segments is described in this solution:
editSelect -nets VDD1
editSelectVia -nets VDD1
editChangeNet -to VDD2
However, it's not so easy to change a logical net name in Encounter. The "name" field for a net isn't editable in the Attribute Editor, there is no "dbSetNetName" command, and dbGet says the "name" attribute of the "net" object type isn't settable:
encounter 1> dbGet top.nets.?h
name: string, Canonical (flat) name of the net
If an attribute is settable dbGet will say "settable" after the attribute name. For example:
skipRouting(settable): bool, Specifies that Nanoroute should not route or re-route the net.
So how can we change the net name programatically? How would we take this netlist:
module testcase ();
 wire net;
 BUFX1 i0(.Y(net));
 BUFX1 i1(.A(net));
endmodule
...and turn it into this:
module testcase ();
   wire new_net;
   BUFX1 i0 (.Y(new_net));
   BUFX1 i1 (.A(new_net));
endmodule
Today's puzzler is to write a TCL script called "userChangeNetName" that changes the logical net name of nets programmatically:
proc userChangeNetName {oldNetName newNetName} {
  <your solution here>
Leave your solution as a comment below. I'll post further discussion and a round-up on Friday.
We're looking to change the net name logically so don't worry about things like wire segments or physical I/O pins.
For extra credit, check whether your scripted solution can handle the case where the net is connected to an I/O port and/or connected through Verilog hierarchy like top-level net "in" and "net2" in this example:
module testcase (in);
 input in;
 wire net1, net2;
 BUFX1 i0(.Y(net1));
 BUFX1 i1(.A(net1));
 BUFX1 i2(.A(in));
 BUFX1 i3(.Y(net2));
 a i_a(.in(net2));
endmodule
module a(in);
 input in;
 BUFX1 i0(.A(in));
endmodule
Related Reading:
  • Encounter Puzzler #1: Where did my fences go?
  • Encounter Puzzler #2: Finding registers beneath a hierarchy
I'll look forward to seeing your solutions!
Update: Click here to see solutions and discussion about this puzzler
Bob Dwyer
