  3. Encounter Quick Tip: Finding Available Cell Masters with…
BobD
BobD
dbGet
finding cells
cell masters
filler cells
encounter
Digital Implementation
quick tip
Encounter Quick Tip: Finding Available Cell Masters with dbGet
28 Sep 2011 • 1 minute read
When you first start using dbGet, many of your queries branch off the "top" keyword and then traverse to "insts" or "nets". These searches return a list of all the instances or nets in the design. But sometimes it's necessary to query the available cell masters -- some of which may or may not be instantiated.
Common reasons for needing this are for finding things like well taps, end caps, antenna diodes and filler cells. You have a hunch what these cells are called for the library you're working on and you'd like to search through all of the cell masters currently loaded in the design.
Say for example you want to tell the tool which cells should be used as fillers. (Fillers are physical-only instances added after placement to fill gaps between standard cells to provide standard cell rail and well continuity). You can have a hunch they're called FILL-"something". Here's how to use dbGet to find the names of all the cell masters available that match FILL*:
encounter 1> dbGet head.allCells.name FILL*
FILL1 FILL16 FILL2 FILL32 FILL4 FILL64 FILL8
You can pass the output directly to setFillerMode, then call addFiller to add the instances to the design:
encounter 2> setFillerMode -core [dbGet head.allCells.name FILL*]
encounter 3> addFiller
Although "top" is by far the common dbGet starting point, the "head" pointer provides a link to technology information like layers, vias and more. Give it a look next time you're seeking to find technology information rather than design-specific data.
For more information on dbGet check out this post on Getting Started with dbGet.
Hope this helps.
-Bob Dwyer
