  3. Five-Minute Tutorial: Default Naming Conventions in Encounter…
Kari
Kari
EDI
naming
timing debug
tutorial
encounter
Digital Implementation
default naming conventions
five-minute
Five-Minute Tutorial: Default Naming Conventions in Encounter Digital Implementation (EDI)
27 Feb 2012 • 2 minute read
This is a topic that frequently comes up on both internal and external forums. And the answer is right in the Encounter Digital Implementation System (EDI) User Guide, but unless you already know that, you may not think to look for it there.
At some point, all of us have looked at a timing report, and reviewed the list of cells that EDI added during timing optimization. Then we wondered, "Hmmm. What does that prefix mean?" I'm sure you've seen the prefixes of the form FE_PHC, FE_RC, FE_OFC, etc. They do have specific meanings, and when debugging a timing path, it can be very helpful to know where these cells came from.
The following list is located in the EDI User Guide. It's at the end of the Optimizing Timing chapter, in a section called Default Naming Conventions.
Prefix
Description
Command
FE_MDBC
Instance added by multi-driver net buffering
optDesign
FE_MDBN
Net added by multi-driver net buffering
optDesign
FE_OCP_DRV_C
Instance added by DRV fixing
optDesign
FE_OCP_DRV_N
Net added by DRV fixing
optDesign
FE_OCP_RBC
Instance added by rebuffering
optDesign
FE_OCP_RBN
Net added by rebuffering
optDesign
FE_OCPC
Instance added by critical path optimization
optDesign
FE_OCPN
Net added by critical path optimization
optDesign
FE_OFC
Buffer instance added by rule-based buffer insertion
insertRepeater/optDesign
FE_OFN
Buffer net added by rule-based buffer insertion
FE_PHC
Instance added by hold time repair
optDesign
FE_PHN
Net added by hold time repair
optDesign
FE_PSBC
Instance added by buffer insertion in optDesign -postRoute
optDesign
FE_PSBN
Net added by buffer insertion in optDesign -postRoute
optDesign
FE_PSC
Instance added by postroute setuprepair
optDesign
FE_PSN
Net added by postroute setup repair
optDesign
FE_RC
Instance created by netlist restructuring
optDesign
FE_RN
Net created by netlist restructuring
optDesign
FE_USC
Instance added during useful skew optimization
optDesign
Hopefully this information will help you debug a timing path gone wrong, and prompt you to check out the EDI User Guide!
Here are two previous blogs related to debugging timing in EDI:
Demo: Calling Global Timing Debug for a Single Path
An Interview with Global Timing Debug Architect Thad McCracken
- Kari Summers
