  3. How to Change a Net Name
Kari
Kari
Digital Implementation
7 Nov 2008 • Less than one minute read
This is a question that comes up once every few months or so: "How do I change the name of a net that I routed by hand? Do I have to delete it and route it again?"
The answer (thankfully) is no. When would you find yourself in this situation? One example is that you hand-routed a complicated analog or power net, and then got a netlist ECO in which the connections didn't change, but the name of the net did. You could always write out a DEF file, edit the net name there, and read the new DEF back in, but there's an easier way.
Here's how to do it:
First, you need to select the wires (and vias) of the net that you want to change the name of:
      editSelect -nets AVDD1
      editSelectVia -nets AVDD1
Then, use the editChangeNet command to rename the net to its new name: (editChangeNet works on the selected net)
      editChangeNet -to AVDD2
Easy!
