  3. How to Create a Repeating Power Switch Pattern with add…
Kari
Kari
Low Power
Digital Implementation
addpowerswitch
How to Create a Repeating Power Switch Pattern with addPowerSwitch
9 Feb 2009 • 2 minute read
I mentioned in my last post that I'd been having lots of fun with power switches lately. One thing I learned how to do was to set up a regular pattern for my switch columns. My first stop for learning something new is always the documentation, but there are so many different options to the addPowerSwitch command that I asked one of our experts, Richard Chou, for help. Setting up a pattern is really quite easy!
Here is a basic addPowerSwitch command for creating switch columns with just one type of cell. This will put the same switch buffer cell on every row in the column:
addPowerSwitch -column \
                         -offPD PD_A \
                         -switchModuleInstance top_sw_mod \
                         -enablePinIn sw_en_in \
                         -enablePinOut sw_en_out \
                         -enableNetIn sw_in\[0\] \
                         -enableNetOut sw_out \
                         -leftOffset 8.4 \
                         -bottomOffset 0.0 \
                         -horizontalPitch 50.96 \
                         -globalSwitchCellName SWITCHBUFX16
Now, let's say you found that the switches are taking up a bit too much real estate or you need some more powerful switches to minimize IR-drop. Instead of the same switch buffer cell on every row in the column, you want every fourth row to be a switch buffer cell, and the rows in between to be non-buffer switch cells, which are smaller and source more current. This will set up a repeating pattern, starting at the bottom, of one switch buffer cell followed by three non-buffer switch cells:
                         -offPD PD_A \
                         -leftOffset 8.4 \
                         -bottomOffset 0.0 \
                         -globalSwitchCellName {SWITCHBUFX16 SWITCHX16} \
                         -globalPattern {SWITCHBUFX16 SWITCHX16 SWITCHX16 SWITCHX16}
Finally, let's say you had a really complicated pattern you wanted to implement. Something like one switch buffer, three switch, one switch buffer, two switch, two switch buffer, three switch. (Hey, it could happen!) That -globalPattern argument is going to get pretty long and unreadable, right? Well, it doesn't have to. You can assign a cell id to each type of cell you're using, then use these cell ids as a kind of shorthand in creating the pattern, like this:
                         -offPD PD_A \
                         -leftOffset 8.4 \
                         -bottomOffset 0.0 \
                         -globalSwitchCellName {{SWITCHBUFX16 SB1} {SWITCHX16 S1}} \
                         -globalPattern {SB1 S1 S1 S1 SB1 S1 S1 SB1 SB1 S1 S1 S1}
I think you could also do this, but the previous example looks cleaner in a script, at least to my eye:
                         -globalPattern {SB1 {S1 * 3} SB1 {S1 * 2} {SB1 *2} {S1 * 3}}
Anyone out there have some interesting switch patterns they've been playing with? Let me know in the comments.
