  3. iSpatial: Next-Generation Common Physical Optimization …
Neha Joshi
Neha Joshi
Genus
Logic Design
Synthesis
ispatial
physical implementation
iSpatial: Next-Generation Common Physical Optimization Flow
22 Mar 2021 • 1 minute read
With advanced-process nodes, a standard cell's physical delay, net delay, and congestion all lead to a higher netlist requirement. Genus/Innovus iSpatial bridges synthesis and implementation with integrated core engines and unified physical optimization. It gives great power, performance, and area (PPA) results in full flow and predictability for front-end designers about the physical effects that can be expected during Place & Route (P&R) to make better design decisions faster.
Are you excited to explore more?
  • What is Genus iSpatial?
  • How to do iSpatial set up in Genus?
  • How to do iSpatial Synthesis in Genus?
  • How to run iSpatial flow in Genus?
  • How to handoff files from Genus to Innovus?
  • What are some of the frequently asked questions on iSpatial flow?
 There is a ONE-STOP solution to all these queries in the form of videos on "Exploring iSpatial Flow in Genus Synthesis Solution"; refer to the channel videos on https://support.cadence.com (Cadence login required).
​This channel contains videos that explore iSpatial flow in Genus Synthesis Solution. Videos explain iSpatial methodology, how to set up and run iSpatial flow in Genus. It also shows how to handoff files from Genus for Innovus and script for running Innovus pre-CTS run. The channel also covers frequently asked questions on iSpatial flow.
Video Titles:
iSpatial: Next-Generation Common Physical Optimization flow (Video)
What Is Genus iSpatial? (Video)
How to do iSpatial Setup? (Video)
How to Do iSpatial Synthesis? (Video)
How to Run iSpatial Flow in Genus Synthesis Solution? (Video)
How to Handoff Files From Genus for Innovus? (Video)
Frequently Asked Questions: iSpatial (Video)
Enhance the Genus Synthesis experience with videos: Genus Synthesis Solution: Video Library
For any questions, general feedback, or future blog topic suggestions, please leave a comment.
