  3. Let's Unveil the Power of Cloning and Rewiring for Your…
Neha Joshi
Neha Joshi
scan
DFT
Genus
clone
IEEE 1500
wrapper
Let's Unveil the Power of Cloning and Rewiring for Your Scan-Inserted Design!
20 Feb 2023 • 2 minute read
Are you fascinated by clones? We can bring the same excitement to your design flow. Want to explore the cloning and rewiring concept for the clock gating cells in wrapper cells?
 But let's first overview the wrapper cell.
The IEEE 1500 standard provides a standard interface to create an isolation boundary between a core to be tested and the logic external to the core. The isolation boundary consists of wrapper cells inserted for each functional input and output port on the core.  The GenusTm Synthesis Solution DFT builds the Wrapper Boundary Registers (WBRs) and the logic consisting of the 1500 controller for the serial and parallel interface protocols. In Genus, you can clone and rewire inserted clock gates for wrapper cells.
A suitable combination of cloning and rewiring can help set the right value for the clock signal for the wrapper cell. Are you excited to explore the solution to ensure the cloning of Integrated clock gating cells for the wrapper and other internal flops?
Don't worry; we can help sail your design smoothly in the scan world.
The solution is in the form of the video " How to Clone and Rewire ICGs (Inserted Clock Gates) for Wrapper Cells in Genus Synthesis Solution (Video)," which explains how you can implement cloning and rewiring in Genus with the help of an example circuit; refer to the video on https://support.cadence.com (Cadence login required).
This video explains how to do cloning and rewiring for inserted clock gates during wrapper cell insertion in Genus Synthesis Solution.
​Video Link:
How to Clone and Rewire ICGs (Inserted Clock Gates) for Wrapper Cells in Genus Synthesis Solution (Video) (cadence.com)
Enhance the Genus Synthesis experience with videos: Genus Synthesis Solution: Video Library
For any questions, general feedback, or future blog topic suggestions, please leave a comment.
Related Training Bytes:
How to Insert IEEE 1500 Wrapper Cell in Genus Synthesis Solution? (Video)
What Is IEEE Wrapper? (Video)
IEE 1500 Wrapper Insertion Flow in Genus Synthesis Solution (Video)
Related Courses:
  • Genus Synthesis Solution with Stylus Common UI
  • Test Synthesis with Genus Stylus Common UI
  • Advanced Synthesis with Genus Stylus Common UI
