  3. Overcoming Mixed-Signal Design Challenges with Virtuoso…
P Saisrinivas
P Saisrinivas
Virtuoso Schematic Editor
Low Power
Virtuoso Digital Implementation
RTL-to-GDSII
Cadence training
symbol
Virtuoso Layout Suite
Mixed Signal Designers
Overcoming Mixed-Signal Design Challenges with Virtuoso Digital Implementation
19 Jul 2024 • 3 minute read
The world of electronics design thrives on efficient tools that bridge the gap between concept and silicon. Virtuoso Digital Implementation is a powerful ally for mixed-signal designs, which integrate both analog and digital components. This blog post will examine Virtuoso Digital Implementation's capabilities and explore how it can streamline your mixed-signal design workflow.
Virtuoso Digital Implementation in a Nutshell
Virtuoso Digital Implementation is a license package within the Cadence Virtuoso Design Platform. It offers a streamlined RTL-to-GDSII flow to implement smaller digital blocks within a mixed-signal design environment. Here's what makes Virtuoso Digital Implementation stand out:
  • Focus on Small Digital Blocks: Optimized for digital blocks with an instance count of up to 50,000 (expandable to 150,000 with specific configurations), Virtuoso Digital Implementation is ideal for integrating digital logic into your analog-centric design.
  • Leveraging Industry Leaders: Virtuoso Digital Implementation utilizes cut-down versions of the renowned Cadence Genus Synthesis Solution and Innovus Implementation System under the hood. This ensures you get access to proven technologies for logic optimization and place-and-route.
  • Seamless Integration with the Virtuoso Environment: Virtuoso Digital Implementation's key advantage is its tight integration with the Virtuoso Layout Suite. You can launch the synthesis and place-and-route tools directly from the Virtuoso environment, eliminating the need to switch between platforms.
Benefits of Using Virtuoso Digital Implementation
 By incorporating Virtuoso Digital Implementation into your mixed-signal design flow, you can get several benefits:
  • Simplified Workflow: Virtuoso Digital Implementation offers a centralized environment for both digital block implementation and layout editing within the Virtuoso environment. This reduces context switching and streamlines the design process.
  • Faster Time-to-Market: Virtuoso Digital Implementation's streamlined workflow can significantly reduce design turnaround times, allowing you to get your product to market quicker.
  • Improved Design Quality: Leveraging industry-leading synthesis and place-and-route engines from Cadence ensures high-quality digital block implementation within your mixed-signal design.
Who Should Consider Virtuoso Digital Implementation?
 Virtuoso Digital Implementation is a valuable tool for anyone working on mixed-signal designs with smaller digital blocks. It's particularly well-suited for:
  • Analog IC designers who need to integrate digital logic into their designs.
  • Circuit design teams working on mixed-signal applications like data converters, power management ICs, and RF transceivers.
Virtuoso Digital Implementation provides a compelling solution for designers working on mixed-signal projects. Its streamlined workflow, tight integration with the Virtuoso design platform, and access to proven digital design tools can significantly improve design efficiency and time-to-market. Virtuoso Digital Implementation is worth considering if you're looking to optimize your mixed-signal design flow.
I am here to help and guide you on how to learn more about Virtuoso Digital Implementation flow.
Welcome to Virtuoso Digital Implementation, an online course recently released. This course teaches implementing digital blocks using Cadence tools based on the Virtuoso Digital Implementation flow. Also, you can download a lab database after the lecture and get hands-on experience in each stage.
Want to Enroll in this Course?
We organize this Virtuoso Digital Implementation training for you as a "Blended" or "Live" training. Please reach out to Cadence Training for further information.
Register for the Online Training with the following steps:
  • Log on to cadence.com with your registered Cadence ID and password.
  • Select Learning from the menu > Online Courses.
  • Search for Virtuoso Digital Implementation using the search bar.
  • Select the course and click Enroll.
And don't forget to obtain your Digital Badge after completing the training!
Online Courses
  • Cadence RTL-to-GDSII Flow v6.0
  • Virtuoso Digital Implementation Training
Training Byte Videos
  • How Do You Run Placement Optimization in the Innovus Implementation System?
  • How to Run the Synthesis Without DFT?
  • How to Run the Synthesis Flow with DFT?
  • Creating Power Rings, Power Stripes, and Power Rails in the Innovus Implementation System
  • How to Run Power Analysis and Analyze the Results in Innovus?
Happy Learning!
