  3. Power Is HOT and Touches Everything and Everybody! But the…
Neha Joshi
Neha Joshi
Low Power
Genus
Digital Implementation
Synthesis
power optimization
Power Is HOT and Touches Everything and Everybody! But the Challenge Is To Deal With Low Power During Design Synthesis; How?
10 May 2022 • Less than one minute read
Low-Power synthesis is one of the important stages in the full IC flow. Here, you synthesize the design from behavioral description to gates while optimizing for dynamic and leakage power using various techniques. We understand that it is not always easy to estimate power, but Cadence offers a solution in the form of a low-power synthesis flow with Genus.
Are you interested in exploring:
  • What the complete low-power synthesis flow is?
  • What the required inputs are?
  • How to configure power optimization?
There is a ONE-STOP solution to all these queries in the form of videos on "Setting and Running Power Optimization Flow in Genus Synthesis Solution," available on our Customer Support site (Cadence login required).
This channel contains videos that explore the basic low-power synthesis flow of the Genus Synthesis Solution. The videos cover the flow and steps to run the power optimization flow. The videos also explain the various commands and attributes used to run the power synthesis flow.
Video Title
Basic Low-Power Synthesis Flow in Genus Synthesis Solution Stylus CUI (Video) (cadence.com)
Enhance the Genus Synthesis experience with videos: Genus Synthesis Solution: Video Library
