  3. RTL Design Studio: Bridging RTL Design and Physical Imp…
sakshin
sakshin
Digital Implementation
RTL design
RTL debugging
physical implementation
LMS
Joules RTL Design Studio
cadence learning and support
RTL Design Studio: Bridging RTL Design and Physical Implementation
26 Jun 2026 • 2 minute read
Imagine this: your design looks perfect at RTL. Functional checks pass. Everything seems on track. But weeks later—during implementation—you hit unexpected timing violations, congestion hotspots, or power issues.
Now the real cost begins: iteration, rework, delays.
What if you could predict and fix all this much earlier—right at RTL?
Welcome to the RTL Design Studio Training Webinar, where innovation meets efficiency, and guesswork is replaced with data-driven RTL intelligence.
You can watch the recording at Cadence ASK portal with the given link:
CadenceTECHTALK: Design Faster, Debug Smarter - Transform RTL Productivity with Cadence RTL Design Studio
What Makes RTL Design Studio a Game-Changer?
Part of Cadence's Digital Full Flow, RTL Design Studio enables:
White check mark Early power estimation and reduction
White check mark Fast and accurate PPAC insights (power, performance, area, congestion)
White check mark Seamless integration with Genus and Innovus flows
White check mark Strong RTL-to-implementation correlation
This means you don't just design RTL—you design with implementation outcomes in mind.
Webinar Spotlight: Key Topics You'll Explore
  1. Features and Capabilities of RTL Design Studio
  2. PPAC Optimization — Your Competitive Advantage
  3. Smarter Debugging with RDAS
  4. RDAS: Timing Debug
  5. RDAS: Power Debug
  6. RTL Design Studio Graphical User Interface
What Is RDAS?
RTL Debug Assistant System (RDAS) is a built-in debugging and analysis capability within Joules RTL Design Studio, designed to help engineers quickly identify and fix issues at the RTL stage.
It helps analyze different types of RTL design problems, including:
  1. Timing issues – Identifies critical paths and potential violations.
  2. Congestion issues – Highlights areas that may cause routing problems later
  3. Power Issues – Supports Data gating, redundant reset analysis & improvements
  4. Structural issues – Detects inefficiencies or problematic RTL constructs
Conclusion
The RTL Design Studio Webinar is more than training—it's a paradigm shift.
From reactive debugging to proactive optimization, from late discovery to early insight—this is how modern silicon design is done.
White check mark Design smarter
 White check mark Debug faster
 White check mark Deliver better silicon
References
Enhance your learning with these training resources from Cadence Learning and Support:
  • Joules RTL Design Studio: RTL Productivity and QoR
  • Lab Demo: Analyzing Timing Issues Using RTL Debug Assistant System in Joules RTL Design Studio (Video)
  • Lab Demo: Analyzing Structural Issues Using RTL Debug Assistant System in Joules RTL Design Studio (Video)
  • Lab Demo: Analyzing Congestion Issues Using RTL Debug Assistant System in Joules RTL Design Studio (Video)
  • Analyze Pipeline Slack Using RTLDebug Assistant System in Joules RTL Design Studio (Video)
Access Training Courses via Cadence Learning Management System (LMS).
