  3. RTL-to-GDSII Flow: I Am Not a Tool but Can Help You Implement…
P Saisrinivas
P Saisrinivas
ECO
conformal
Static timing analysis
VLSI
scan
DFT
Integrated Metrics Center
Genus
featured
Cadence blogs
GDSII
code coverage
Tempus
Gate level simualtion
ASIC flow
gds
LEC
Signoff Analysis
RTL
SDF
STA
Cadence Online Support
Floorplanning
RTL-to-GDSII
training
Logic Design
xrun
Equivalence Checking
Layout
digital flow
Digital Implementation
Innovus
physical design
Timing analysis
Cadence Education Services
ATPG
xcelium
RTL2GDSII
Synthesis
signoff
physical implementation
Design specifications
verification
cadence learning and support
RTL-to-GDSII Flow: I Am Not a Tool but Can Help You Implement Your Entire Design!
25 Aug 2022 • 4 minute read
Passion motivates and helps you pursue it further, but gaining expertise requires time and effort. For example, photography is a popular hobby because anyone can take a picture. But to gain expertise requires time and effort to experiment with various techniques to improve your skills.
Likewise, given an innovative design idea, it takes an efficient methodology and implementation flow to generate it to a GDSII. To achieve this, we use RTL-to-GDSII flow, also known as Digital flow or ASIC flow, which includes many stages in designing an IC in the semiconductor industry. Starting from RTL coding, simulating the RTL, synthesizing and testing, implementing the logic as a physical layout, and finally generating a GDSII file after timing signoff, each stage in the flow has unique techniques and complexities.
Don’t get overwhelmed with terminology. Get hooked on the world of Cadence_RTL-to-GDSII_Flow 4_0 and start exploring the ABCs of the design flow process.
This course teaches how to implement a design idea from RTL-to-GDSII flow using Cadence® tools. You will learn how to deal with these challenges while running the flow, such as resolving errors in the log file, debugging the timing violations, and fixing setup and hold violations. After completing the lecture, you can download a lab database and manual to test your knowledge at every stage.
After completing this course, you will be able to:
  • Code a design in Verilog as per the design specification provided
  • Compile, elaborate, and simulate your design
  • Synthesize your design
  • Design for test
  • Run equivalency checking at different stages of the flow
  • Floorplan a design
  • Run placement, optimization, clock tree synthesis, and routing on your design
  • Run signoff checks to ensure that can able to fabricate a chip.
  • Write out a GDSII file.
Steps to follow to get enrolled in this course:
  1. Log on to support.cadence.com with your registered Cadence ID and password.
  2. Select Learning from the menu > click Online Courses.
  3. Search for Cadence_RTL-to-GDSII_Flow 4_0 using the search bar.
  4. Select the course and click the Enroll button.
Digital Badge Available
The course also has an associated exam to certify your knowledge of RTL-to-GDSII flow and display a digital badge on your Linkedin profile – Cadence RTL-to-GDSII v4.0 (Badge Exam)
Online courses
  • Xcelium Simulator
  • Verilog Language and Application
  • Metric Driven Verification Using Cadence vManager
  • Genus Synthesis Solution
  • Innovus Implementation System
  • Tempus Signoff Timing Analysis and Closure
  • Conformal Equivalence Checking
Blogs
  • Are You Planning To Synthesize Your Design?
  • Floorplanning Frustrations Got You Down? Help Is on the Way!
Training Bytes
  • Xcelium Training Bytes
  • Genus Training Byte References
  • Innovus Training Byte videos
  • Tempus Training Bytes
 For more information on Cadence’s digital design and signoff products and services, visit www.cadence.com.
Happy learning! Thank You.
