  3. SSV 20.1 Base Release Now Available
SSV Release Team
SSV Release Team
Vector Profiler
Signoff ECO
Tempus
Tempus PI
integrated signoff
Power Integrity
Voltus
Voltus-XP
15 May 2020 • 3 minute read
The SSV 20.1 production release is now available for download at Cadence Downloads.
For information about supported platforms, compatibility with other Cadence tools, and details of key issues resolved in the SSV 20.1 release, see the README.txt file.
At the time of publishing, the link above was functional. If you encounter any links that are now obsolete, visit https://downloads.cadence.com, click the LINUX tab, and select the SSV release name you are interested in to access the related files.
Here is a list of some of the important updates made to TempusTM Timing Signoff Solution and VoltusTM IC Power Integrity Solution for the 20.1 production release:
Tempus
  • Tempus Power Integrity Solution Introduced
    The Tempus Power Integrity (Tempus PI) solution integrates the Tempus and Voltus solutions to:
    - perform IR-aware timing analysis and failure fixing
    - reduce IR drop margins to improve power and area
    - utilize proprietary vectorless-based algorithm to identify critical paths most likely impacted by IR drop
    For detailed information about Tempus PI, refer to the Tempus User Guide on Cadence Support portal.
  • Enhanced Support for Integrated Signoff Closure
    Tempus Signoff ECO now has the capability to perform DRV, Setup, Hold, and Power Optimization together in the path-based analysis (PBA) mode. This functionality is available through the Innovus cockpit. The new flow enhances user experience by providing easy-to-use Tempus ECO solution. It results in fewer iterations for improving power, performance, and area (PPA).
For more details about the new and enhanced features introduced in this release, see Tempus What's New.
Voltus
  • New XP Processing Mode to Achieve Large Capacity and Scalable Performance
    Voltus introduces the new Extensively Parallel (XP) mode aimed at providing performance improvements of up to 5X, making it easier to work on giga-scale designs. The XP mode enhances the Voltus solution's massively parallel execution with more efficient scalability on thousands of CPUs and hundreds of machines.
    For detailed information about the Voltus-XP technology, refer to the Voltus User Guide on Cadence Support portal.
  • Tempus Power Integrity Flow for IR-Sensitive Path Prediction
    The new Tempus Power Integrity (Tempus PI) flow provides a better solution to find and fix IR-sensitive timing paths that result in timing failures. This flow accurately predicts IR drop on the critical paths with Voltus vectorless analysis, and enables automated fixing using Innovus and Tempus IR-ECO.
    For detailed information about Tempus PI, refer to the Voltus User Guide on Cadence Support portal.
  • Simplification of the Vector Profiler Flow
    The use model of the Vector Profiler flow has been simplified and streamlined for easy adoption and better usability.
    For detailed information, refer to the Voltus What's New document on Cadence Support portal.
  • Combined Vector Profiling and Dynamic Power Analysis for Multiple Windows
    Supports combining vector profiling and dynamic power analysis to identify windows with maximum activity to further drive dynamic vector-based power analysis.
    For detailed information, refer to the Voltus User Guide on Cadence Support portal.
For more details about these and all the other new and enhanced features introduced in this release, see Voltus What's New.
Please send questions and feedback to ssv_rm@cadence.com.
To receive SSV release announcements like this one, and other SSV-related information, directly in your mailbox, type your email ID in the Subscriptions field at the top of the page and click SUBSCRIBE NOW.
SSV Team
