  3. The Best Way to Learn - Innovus Implementation with Stylus…
Malavika Goda
Malavika Goda
digital badge
live training
Stylus Common UI
Innovus Implementation System
Cadence training
Digital Implementation
cadence learning and support
The Best Way to Learn - Innovus Implementation with Stylus Common UI
5 Feb 2024 • 2 minute read
The Cadence Innovus Implementation System provides an integrated solution for RTL to GDSII design flow and is equipped to handle the most challenging designs. Each stage of the design implementation flow, such as placement, optimization, routing, and clock tree synthesis, has unique capabilities that can help the user achieve better turnaround time (TAT) and power, performance, and area (PPA). The Innovus system architecture minimizes design iterations and provides the runtime boost you’ll need to get to market faster.
In this course, you learn how to use the Innovus Implementation System software using the Stylus Common User Interface (UI). You will learn several techniques for floorplanning and placement using the GigaPlace solver-based placement, implementing timing closure strategies with a multi-threaded, layer-aware timing and power-driven optimization engine to reduce dynamic and leakage power. You will learn how to set up and run the concurrent clock and datapath optimization engine to enhance cross-corner variability and boost performance with reduced power. You will learn how to diagnose and fix routing violations as well as explore some examples of design challenges and solutions. You will also learn database access commands, wire editing, metal fill, engineering change orders (ECOs), and physical verification. This course also covers the topic of implementing hierarchical design using the Innovus Implementation System starting from floorplanning, creating hierarchical blocks, placement, optimization at block and top level and closing timing. You will learn about the concept of blackboxes and flexModels, and explore the Integrated Hierarchical Database (iHDB)
Upcoming Sessions
If that is something of interest to you, we would like to invite you to join our "live" training(s) @Cadence Feldkirchen planned from 04-07 March 2024 in Feldkirchen:
  • Innovus Block Implementation with Stylus Common UI
  • Innovus Hierarchical Implementation with Stylus Common UI
Please contact Training Germany if you would like to register for this training(s).
Become Cadence Certified
Cadence Training Services offers a digital badge for this training course(s). This badge indicates proficiency in a certain technology or skill and gives you a way to validate your expertise to managers and potential employers. You can highlight your expertise by adding this digital badge to your email signature or any social media platform, such as Facebook or LinkedIn.
If you are interested but can´t make the date or if you would like an exclusive training for you and your colleagues please contact us at Cadence Training.
To stay up to date with the latest news and information about Cadence training and webinars, subscribe to Cadence Training emails.
Please find additional corresponding instructional Training Bytes videos in our Cadence Learning and Support Portal.
Related Trainings
  • Genus Synthesis Solution with Stylus Common UI
  • Innovus Low-Power Flow with Stylus Common UI
  • Innovus Clock Concurrent Optimization Technology with Stylus Common UI
Related Training Bytes
  • Demo: Customizing Bindkeys in Innovus
  • Demo: Clearing Floorplan Objects in Innovus
  • Demo: Interactive Floorplanning Using the Floorplanning Toolbox in Innovus
  • Demo: Creating Placement Blockages, Halos, and Routing Blockages in Innovus
  • Demo: Starting the Innovus Software, Importing and Viewing a Design
Related Blogs and Videos
  • Join Us and Learn from the Cadence Training Offerings
  • Knowledge Booster Training Bytes – Find and Enroll in a Cadence Online Training Course
  • Do You Want to Flaunt Your Expertise? Grab the Digital Badge Today!
  • Cadence Wins Prestigious Support Experience Award at SX Live 2023
  • Getting Started with Cadence Learning and Support System (Video)
