  3. The Odyssey of a Great Floorplan
VNelson
VNelson
Foorplanning
training bytes
digital implementation
Innovus
12 Aug 2026 • 5 minute read
With the recent release of The Odyssey, audiences are once again following an epic journey filled with planning, obstacles, course corrections, and ultimately reaching a destination through skill and perseverance. While the world of VLSI physical design may seem far removed from ancient Greek adventures, experienced implementation engineers know that creating a successful chip floorplan is an odyssey of its own.
Every successful design begins with a journey. Before routing can be completed, timing can be optimized, or silicon can be manufactured, engineers must first navigate a sequence of critical floorplanning decisions. Much like Odysseus charting a path home through uncharted waters, physical designers must carefully guide a design from a collection of logical elements into an implementation-ready layout.
In our Innovus Basic Floorplanning video series, we follow that journey step by step, showing how each milestone contributes to a successful destination.
Setting Sail: Bringing the Design into the Physical World
Every journey starts with preparation. For Odysseus, it was assembling ships and crews. For physical designers, it begins by bringing together the information needed to construct the design database.
The first stage of the floorplanning journey focuses on importing the design and establishing the environment that will support all subsequent implementation activities. Logical descriptions, technology information, and timing views come together to create a foundation upon which every later decision depends. Without this foundation, the voyage cannot begin.
Charting the Map: Defining the Territory
A voyager cannot navigate without a map. Similarly, a chip cannot be implemented without defining its physical boundaries.
The next step establishes the overall dimensions of the design and allocates space between the core logic and the outer boundaries. These decisions influence placement, routing resources, congestion behavior, and overall design efficiency. What may seem like simple geometric choices at this stage frequently have consequences that ripple throughout the remainder of the implementation. Just as a captain studies coastlines and distances before leaving port, designers must understand the terrain before proceeding.
Navigating Complex Landscapes
Not every journey follows a straight path. The route home in The Odyssey is filled with unusual islands, obstacles, and detours. Modern SoC floorplans face similar complexity.
Design teams often need to create regions, placement constraints, and specialized floorplan shapes that reflect architectural requirements. Some areas must remain isolated. Others require guidance to influence placement behavior. In increasingly sophisticated designs, even the shape of the floorplan itself may depart from a simple rectangle. These techniques help engineers shape the physical landscape before major design elements arrive.
Positioning the Giants
In every epic story, massive landmarks define the journey. In physical design, those landmarks are hard macros. Memories, IP blocks, and other large structures consume significant portions of the layout and strongly influence routing patterns. Their locations determine channel widths, congestion hotspots, and connectivity efficiency throughout the design.
Our videos explore both the strategic placement of these critical structures and the techniques used to refine their arrangement. Engineers learn how to organize large blocks, create orderly arrays, maintain spacing, and analyze connectivity between major design components. Getting macro placement right early often determines whether the remainder of the implementation journey proceeds smoothly or becomes a struggle against congestion and timing challenges.
Reading the Signs
Throughout The Odyssey, travelers continually assess their surroundings and adjust their course. Successful floorplanning requires the same mindset.
Once macros are positioned, designers must evaluate utilization levels and routing channels to identify warning signs before they become serious obstacles. Congestion issues discovered late in implementation can significantly impact schedule and quality. Early reporting and analysis provide valuable insight into the health of the floorplan and reveal whether corrective action is necessary.
Adjusting the Course
Even the best plans require refinement. As designers review utilization and routing characteristics, they often discover opportunities to improve channel widths or redistribute available space. Rather than rebuilding from scratch, floorplans can be resized and adjusted while preserving the work already completed. Like a navigator correcting course after encountering changing conditions at sea, engineers make targeted modifications that improve the likelihood of a successful implementation.
Building Safe Passageways
Odysseus avoided dangerous waters whenever possible. Physical designers create their own safe passageways through the use of placement restrictions, routing constraints, and protective regions around sensitive structures. These mechanisms help prevent overcrowding, preserve routing resources, and maintain design quality. They guide implementation tools toward more effective solutions while reducing the risk of congestion-related problems. Such safeguards become increasingly important as designs grow larger and more complex.
Automating the Wisdom of Experience
One hallmark of mature engineering methodologies is the ability to automate best practices.
Experienced floorplanning engineers recognize problematic regions, narrow channels, and placement concerns. Modern implementation tools can apply that expertise automatically by identifying troublesome areas and creating optimization structures where they are needed.
This capability helps transform a good floorplan into a great one while reducing manual effort and improving consistency across designs.
Powering the Voyage
No ship travels without energy. Likewise, no chip can function without a robust power delivery network.
The next phase of the journey focuses on constructing the infrastructure that distributes power throughout the design. Engineers establish power connectivity, create distribution structures, and build the framework that will ultimately support reliable operation.
A well-designed power network is often invisible to end users, yet it is every bit as essential as the hull of a ship crossing the sea.
Reaching Ithaca: Completing the Floorplan
In The Odyssey, the journey culminates with Odysseus finally reaching home after overcoming countless challenges. Floorplanning reaches a similar milestone when power connectivity is completed, standard-cell placement begins, design health checks are reviewed, and the implementation database is saved for the next stages of the flow.
At this point, the floorplan has evolved from an abstract concept into a carefully engineered physical foundation ready for optimization and routing.
Every Great Chip Has an Odyssey
The appeal of The Odyssey has endured for centuries because it captures a universal truth: meaningful achievements are rarely accomplished in a single step. Success comes from a sequence of decisions, adjustments, lessons learned, and steady progress toward a goal.
The same is true in physical design. A successful floorplan is not simply created. It is discovered through a journey that begins with understanding the design, continues with careful planning and analysis, and concludes with a robust foundation for implementation success.
Whether you're guiding a hero across the Mediterranean or guiding a billion-transistor design toward tapeout, the principle remains the same: The destination matters, but the journey is where excellence is built.
Start your own floorplan odyssey by watching the Innovus Basic Floorplanning video series.
