  3. Training Insights - What's Your Weekend Plan? How About…
Neha Joshi
Neha Joshi
digital badge
Genus
training bytes
Synthesis
online training
Online Support
Training Insights - What's Your Weekend Plan? How About an Interactive Tour of the Genus Synthesis Solution World?
18 Jan 2023 • 3 minute read
Well, we know you are busy, but it's time to develop your expertise in the synthesis domain with the Genus Synthesis Solution. How? You can plan to complete the Genus Synthesis Solution with Stylus Common UI training.
The ultimate goal of the Cadence® GenusTm Synthesis Solution is very simple: deliver the best possible productivity during register-transfer-level (RTL) design and the highest quality of results (QoR) in the final implementation. The training and lab exercises are designed to help you achieve these goals. The steps to run the lab exercises are included as lab instructions in the interactive lab book and PDF format.
And now the exciting part is we are ready with a quick tour of the Genus Synthesis Solution training lab videos! Yes, you got it right. We can help expedite your learning goal with hands-on experience with the tool. And these lab videos gear up the learning speed. You can refer to each lab module's lab instructions in demo format. This will help you speed up the tool ramp-up and quickly perform the lab steps if you are stuck. You might be a beginner in the synthesis world, but we can help you sail through it smoothly.
And hence we have created a series of short channel lab videos on Running Synthesis Flows Using GenusTm Synthesis Solution available on our Customer Support site. This channel contains videos demonstrating various synthesis flows like basic, physical (iSpatial), low-power, test, etc., using Genus Synthesis Solution in Stylus Common UI mode. The videos cover step-by-step ways to run each flow stage. They also show basic debugging for the issues during the elaboration and reading timing constraints. The video also explores the Genus GUI features.
Video Titles:
How to Run the Setup for Synthesis, Load Libraries, and Design And Elaborate The Design Module in Genus Synthesis Solution? (Video)
How to Read The Design's Timing Constraints Into Genus Synthesis Solution?
How to Synthesize the Design in Genus Synthesis Solution? (Video)
Steps for Multi-Mode Multi-Corner (MMMC) Flow in Genus Synthesis Solution (Video)
Exploring the Genus Synthesis Solution Design Hierarchy And Querying Design Objects (Video)
Exploring The Graphical User Interface of Genus Synthesis Solution. (Video)
Running the iSpatial Synthesis Flow in Genus Synthesis Solution (Video)
How to Check And Modify the Floorplan After Running iSpatial Flow in Genus Synthesis Solution? (Video)
Running the Low-Power Synthesis Flow to Optimize The Leakage And Dynamic Power in Genus Synthesis Solution (Video)
Running Test Synthesis Flow to Insert Scan Chains And Improve the Testability of a Design in the Genus Synthesis Solution (Video)
How to Set the Timing Constraints in Genus Synthesis Solution (Video)
What's Next?
Grab your Digital Badge after finishing the training and flaunt what you did over the weekend.
Related Resources:
Enhance the Genus Synthesis experience with videos: Genus Synthesis Solution: Video Library
Related Blogs:
Do You Want to Flaunt Your Expertise? Grab the Digital Badge Today!
