  3. Training Insights – Struggling with Synthesis to Achieve…
Neha Joshi
Neha Joshi
digital badge
Genus
online courses
exam
training
training bytes
Genus Synthesis Solution
Synthesis
online training
Online Support
Training Insights – Struggling with Synthesis to Achieve Best PPA Results?
28 Feb 2024 • 2 minute read
The ultimate goal of the Cadence Genus Synthesis Solution is very simple: deliver the best possible productivity and Power, Performance, and Area (PPA) during register-transfer-level (RTL) logic synthesis.
The real design synthesis journey is not always rosy; there might be some PPA issue or other!!
  • Is there any way to develop your expertise in the synthesis domain using the Genus Synthesis Solution?
  • How do you tackle and debug the problem scenarios you typically encounter in a synthesis flow?
  • How do you build the expertise to debug problems in synthesizing complex designs when optimizing for timing, area, and power?
  • How do you dive deeper and understand the synthesis results?
We have a solution in the form of comprehensive training!
Trainings
Fill the knowledge gap with the latest Genus trainings to learn how to use the synthesis flow to achieve better PPA and pass design to the place-and-route tools.
  • Genus Synthesis Solution with Stylus Common UI
Identify the features of Cadence Genus Synthesis Solution with Stylus Common UI and how Genus fills the SoC design productivity gap.
Build your concepts and learn techniques for constraining designs, run static timing analysis, evaluate datapath logic, run physical synthesis, optimize for low-power structures, analyze DFT (design for testability) constraints, and interface with other tools in the Genus Stylus Common UI.
The training guides you on how to run a complete synthesis flow on a design with the given specifications and optimize it for area, timing, and power.
  • Advanced Synthesis with Genus Stylus Common UI
Enhance your expertise with advanced synthesis techniques to improve and achieve the best PPA results and align with the place and route.
The training helps you debug problems in synthesizing complex designs when optimizing for timing, area, and power. There are example problem scenarios that you typically encounter in a synthesis flow and how you can debug them.
Labs
We ensure that your learning journey goes smoothly with hands-on labs covering various design scenarios.
The training and lab exercises are designed to help you achieve these goals. The steps to run the lab exercises are included as lab instructions in the interactive lab book.
Lab Videos
And now the exciting part is, to help you further, we have engaging videos on the training labs. You can refer to each lab module's instructions in demo format. This will help accelerate your tool ramp-up and more quickly perform the lab steps if stuck.
You might be a beginner in the synthesis world, but we can help you sail through it smoothly.
To embark on your journey as a synthesis expert, we have created a series of short channel lab videos on our Customer Support site.
How to Run the Setup for Synthesis, Load Libraries, and Design And Elaborate The Design Module in Genus Synthesis Solution? (Video)
Demo: Analyze, Synthesize, and Optimize the design for the best possible timing with the Genus Synthesis Solution (Video)
Short Training Bytes/Videos
Enhance the Genus Synthesis experience with short videos: Genus Synthesis Solution: Video Library
What's Next?
Grab your Digital Badge after finishing the training and flaunt what expertise you have built up. Blush
Related Blogs
Do you want to Flaunt your Expertise? Grab the Digital Badge Today!
Recording Now Available: Intro to Genus iSpatial Synthesis Flow Webinar - Digital Design - Cadence
Digital Design - New Training Releases, Blogs, Videos and Digital Badges in 2023
