  3. Training Insights - Unveil the Track to Become an Expert…
Neha Joshi
Neha Joshi
digital badge
conformal
Genus
advanced synthesis
training bytes
Synthesis
stylus
online training
Online Support
Training Insights - Unveil the Track to Become an Expert in Synthesis
19 Oct 2023 • 2 minute read
Are you wondering what is the next step to becoming an expert in the synthesis using the Genus Synthesis Solution? We are sure you must have already completed the training Genus Synthesis Solution with Stylus Common UI. What's next? The real design synthesis journey is not always rosy; there might be some PPA issue or other!
Are you curious about how to build the expertise to debug problems in synthesizing complex designs when optimizing for timing, area, and power?
How do you dive deeper, understand the results, and debug the issues?
How about training that includes problem scenarios that you typically encounter in a synthesis flow and how you can debug them?!
We have the Advanced Synthesis with Genus Stylus Common UI training to help you learn how to use the synthesis flow to achieve better quality of results for the place-and-route tools. The training and lab exercises are designed to help you achieve these goals. The steps to run the lab exercises are included as lab instructions in the interactive lab book and PDF format.
The exciting part is, to help you further, we have engaging videos on the training labs. Yes, you got it right. We can help expedite your learning goal with hands-on experience with the tool. And these lab videos gear up the learning speed. You can refer to each lab module's lab instructions in demo format. This will help you speed up the tool ramp-up and quickly perform the lab steps if you are stuck. You might be a beginner in the synthesis world, but we can help you sail through it smoothly.
To embark on your journey as a synthesis expert, we have created a series of short channel lab videos on 'Exploring Advanced Synthesis Optimization Using Genus Synthesis Solution' available on our Customer Support site. This channel contains videos demonstrating advanced synthesis optimization techniques like retiming, optimizing datapath, etc. It also covers running iSpatial flow with the correct DEF file. The video also explores modifying and editing the floorplan using the Genus Layout GUI. The video also covers running a Conformal Equivalency Checker for the retimed design.
Training Videos
Demo: Exploring MMMC Synthesis Flow in Genus Synthesis Solution (Video)
Demo: Analyze, Synthesize, and Optimize the design for the best possible timing with the Genus Synthesis Solution (Video)
Applying Retiming Techniques to Improve a Design's Timing with Genus Synthesis Solution (Video)
Demo: Running iSpatial Synthesis Flow Using the Correct DEF File in Genus Synthesis Solution (Video)
Demo: How to See Cell Movement in the Layout Tab of the Genus Synthesis Solution GUI (Video)
Demo: Exploring Layout Tab Tool Bar in Genus Synthesis Solution GUI (Video)
Demo: How to Edit the Floorplan in Genus Synthesis Solution Layout GUI? (Video)
Demo: Verifying Retimed Design From Genus Synthesis Solution Using Conformal Equivalence Checker (Video)
What's Next?
Grab your Digital Badge after finishing the training and flaunt your expertise!
Enhance your Genus Synthesis experience by watching the video Genus Synthesis Solution: Video Library, and reading this blog post Recording Now Available: Intro to Genus iSpatial Synthesis Flow Webinar.
